Could a fresh eyes check this subroutine why stop working in this part
(command "MASSPROP" obj "" "Y" wPath)
(defun C:CEN ( / doc index obj objects objlay objlist objtype )
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(LM:startundo doc)
;(setq obj (getpoint "Pick inside closed area"))
(setq objects (ssget '((-4 . "<OR")(0 . "LWPOLYLINE")(0 . "REGION")(-4 . "OR>")))
obj (ssname objects 0))
(while obj
(setq objlist (entget obj))
(setq objtype (cdr (assoc 0 objlist)))
(setq objlay (cdr (assoc 8 objlist)))
((and (= objtype "LWPOLYLINE") (= (cdr (assoc 70 objlist)) 1)) (command "REGION" obj "") (setq obj (entlast)) (get_centroid_point))
((= objtype "REGION") (get_centroid_point)))
(setq index (+ index 1)
obj (ssname objects index))
(LM:endundo doc)
(princ "\n q_|_|| _\\|| q_|| _\\| ")
(princ "\n Type CEN to invoke the lisp")
(defun get_centroid_point (/ wpath open-a data vlen X-value Y-value c-point objtype ss )
(setq fd (getvar "filedia")) (setvar "FILEDIA" 0)
(setq cd (getvar "CMDECHO")) (setvar "CMDECHO" 0)
(command "LAYER" "set" objlay "")
(setq wPath nil)
(if (setq wPath (findfile "ACAD.PAT"))
(setq wPath (vl-filename-directory wPath))
(or (eq "\\" (substr wPath (strlen wPath)))
(setq wPath (strcat wPath "\\data")))))
(setq datafile (strcat wPath ".mpr"))
(setq open-a (open datafile) "r")
(setq data "" )
(while (not (wcmatch data "Centroid:*"))
(setq data (read-line open-a))
(setq vlen (- (strlen data) 26)
X-value (atof (substr data 26 vlen))
Y-value (atof (substr (read-line open-a) 26 vlen))
c-point (list X-value Y-value)
(close open-a)
(if (= objtype "LWPOLYLINE")
(command "EXPLODE" obj)
(setq ss (ssget "p")
obj (ssname ss 0))
(command "PEDIT" obj "Y" "Join" ss "" "")
(command "POINT" c-point)
(setvar "FILEDIA" fd)
(setvar "CMDECHO" cd)
;Error
(defun *error* ( msg )
(if val (mapcar 'setvar var val))
(if doc (LM:endundo doc))
(if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
(princ (strcat "\nError: " msg))) (princ))
(defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc))
(defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc)))
