Author Topic: Create Reference  (Read 2096 times)
Fabricio28
Create Reference
« on: April 14, 2014, 10:21:50 AM »
Hi guys,
I'd like to create a block reference just for specific object in my project to other project.
Idon't wanna create a reference of my entire project.
How Can I do that?
Thank in advance
cadtag
Re: Create Reference
« Reply #1 on: April 14, 2014, 01:02:12 PM »
what software are you using, and what kind of reference?  if it's simply an XREF, using the full path option in the XREF dialog ought to do it.
Fabricio28
« Reply #2 on: April 14, 2014, 01:26:50 PM »
I'm using autocad 2012.
I'd like to  create a simply XREF but not the entire project (all layers). Just a few layers or a specific object.
Is it possible?
cadtag
« Reply #3 on: April 14, 2014, 02:28:21 PM »
OK,
no can do.  You can reference a drawing file, but everything that's defined in the DWG is going to be part of the XREF.   Even Paperspace objects, although they will never be visible.
Map3D would let you query in a subset of the drawing, by layer or by area, or other properties, but not vanilla.
A workaround may be to go to the XREF drawing, and WBlock out the objects you want as a new drawing, and the XREF them back into the original drawing, and into you new drawing.
Fabricio28
« Reply #4 on: April 14, 2014, 04:57:47 PM »
whow That's not good
I wish I could do that.
Thank you cadtag!
ChrisCarlson
« Reply #5 on: April 16, 2014, 09:47:16 AM »
You can't perform "wblock"?
danallen
ROBBO
« Reply #7 on: April 16, 2014, 11:49:11 AM »
Perhaps you could make a view of the layers you want to show in you reference file and then use this utility http://www.cadstudio.cz/en/download.asp?file=CopyViews to copy the view(s) from your xref and modify view in your new dwg to suit.
Something to consider.
Cheers, Robbo.
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Fabricio28
« Reply #8 on: April 17, 2014, 03:48:10 PM »
Thank you guys for all suggestions.
Partial open could be good, but I don't know how to use it. I've tried but no sucess.
I really need do that stuff.
There used to be partial open, but I've never used it.
http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-Archive/Partial-Open-Partial-Load-with-xrefs/td-p/80580
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-4981.htm,topicNumber=d0e280829
Regards
« Last Edit: April 17, 2014, 05:09:29 PM by FABRICIO28 »
