Author Topic: How can I know some vlx command?  (Read 2108 times)
aaa120
« on: April 11, 2014, 03:51:42 AM »
I have a vlx files ,but I do not know its command so I can not run it .
How can I know its command to make it run ?
Tharwat
  • Hypersensitive
Re: How can I know some vlx command?
« Reply #1 on: April 11, 2014, 03:55:07 AM »
Hi ,
I think the name of the file should be the command call of the application otherwise it should show in the command line while loading it .
« Reply #2 on: April 11, 2014, 05:33:33 AM »
untested: Perhaps something like this
  1.
  2. (setq before (atoms-family 1))
  3.
  4. ;; load the file
  5.
  6. (setq after (atoms-family 1))
  7.
  8.   (vl-remove-if
  9.     (function (lambda (x) (vl-position x before)))
  10.     after
  11.   )
  12.
bruno_vdh
« Reply #3 on: April 11, 2014, 05:46:48 AM »
Hello,
Otherwise there this variant much like that of Kerry:
((lambda (l)
   (load (getfiled "Select a Lisp File" "" "vlx" 8))
   (foreach cmd (vl-remove-if '(lambda (x) (or (wcmatch x "~C:*") (member x l))) (atoms-family 1))
     (princ "\n")
     (princ cmd)
  (atoms-family 1)
Best regard,
