Author Topic: (100 . "AcDbAlignedDimension") in ssget fliter  (Read 8675 times)
roy_043
  • BricsCAD 18
Re: (100 . "AcDbAlignedDimension") in ssget fliter
« Reply #15 on: April 14, 2014, 10:31:21 AM »
Or:
(ssget "_A" ((0 . "DIMENSION") (-4 . "&") (70 . 1)))
Unfortunately, DXF group 70 for dimensions is not truly bit-coded - I believe your code would also select Diameter & Angular 3-Point dimensions, in addition to Aligned dimensions.
Right, I should checked the documentation. It is a group code with a 'history'.
Strange that AutoCAD doesn't support filtering for group code 100.
Alternative filtering for gc 70:
(ssget "_A" '((0 . "DIMENSION") (-4 . "<NOT") (-4 . "&") (70 . 7) (-4 . "NOT>")))                     ; 0
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 1) (-4 . "<NOT") (-4 . "&") (70 . 6) (-4 . "NOT>"))) ; 1
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 2) (-4 . "<NOT") (-4 . "&") (70 . 5) (-4 . "NOT>"))) ; 2
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 1) (-4 . "&") (70 . 2)))                             ; 3
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 4) (-4 . "<NOT") (-4 . "&") (70 . 3) (-4 . "NOT>"))) ; 4
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 1) (-4 . "&") (70 . 4)))                             ; 5
(ssget "_A" '((0 . "DIMENSION") (-4 . "&") (70 . 2) (-4 . "&") (70 . 4)))                             ; 6
« Reply #16 on: April 14, 2014, 05:09:46 PM »
Interesting approach roy  :-)
beverage
« Reply #17 on: April 14, 2014, 11:12:08 PM »
thank you for all replies
my program will handle aligneddimension and rotateddimension in two diff. ways ,and don't accept other dimension types, so I think using ssget's fliter is not a good way for my goal.
I just feel strange about AutoCAD don't support filtering for group code 100.
I'm using "member" to get the dimension types.
BTW, Lee, you'r very very famous in Chinese lisp writers
« Reply #18 on: April 15, 2014, 04:38:33 PM »
I'm flattered to hear that!  :-)
