Author Topic: (100 . "AcDbAlignedDimension") in ssget fliter  (Read 8638 times)
beverage
« on: April 10, 2014, 04:54:53 AM »
I found "(100 . "AcDbAlignedDimension")" is not affect in ssget fliter
(ssget '((0 . "DIMENSION")(100 . "AcDbAlignedDimension"))) this will selete all type of dimension(such as DbOrdinateDimension,AcDbArcDimension)
(ssget '((100 . "AcDbAlignedDimension"))) this will selete all type of entities
Did I write something wrong?
« Last Edit: April 10, 2014, 04:57:55 AM by beverage »
roy_043
  • BricsCAD 18
Re: (100 . "AcDbAlignedDimension") in ssget fliter
« Reply #1 on: April 10, 2014, 05:40:15 AM »
What you are saying is not correct.
The only problem I see:
(ssget "_A" '((100 . "AcDbAlignedDimension"))) ; => Will also select rotated dimensions.My solution:
(ssget "_A" '((100 . "AcDbAlignedDimension") (-4 . "<NOT") (100 . "AcDbRotatedDimension") (-4 . "NOT>")))
beverage
« Reply #2 on: April 10, 2014, 09:10:34 PM »
It's strange.
I've tried the code in your solution, and tried one more time after your reply
  1. (ssget "_A" '((100 . "AcDbAlignedDimension") (-4 . "<NOT") (100 . "AcDbRotatedDimension") (-4 . "NOT>")))
will select nothing
It's really strange.I give up type judge during select, I plan to use member to judge if  (100 . "AcDbRotatedDimension") in the group code.
I guess it maybe caused by not only 1 (100 . "**")
((-1 . <图元名: 7ffffbb1030>)
(0 . "DIMENSION")
(330 . <图元名: 7ffffb0b820>)
(5 . "12620B")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "S_DETL_REIN")
(100 . "AcDbDimension")
(280 . 0) (2 . "*D442")
(10 45536.0 62515.1 0.0)
(11 45258.5 62647.4 0.0)
(12 0.0 0.0 0.0)
(70 . 33)
(1 . "")
(71 . 5)
(72 . 1)
(41 . 1.0)
(42 . 572.279)
(73 . 0)
(74 . 0)
(75 . 0)
(52 . 0.0)
(53 . 0.0)
(54 . 0.0)
(51 . 0.0)
(210 0.0 0.0 1.0)
(3 . "TSSD_50_50")
(13 44969.9 62622.6 0.0)
(14 45540.7 62582.4 0.0)
(15 0.0 0.0 0.0)
(16 0.0 0.0 0.0)
(40 . 0.0)
(50 . 0.0))
Thank you for your reply
I've just update from 2006 to 2012,and found lots new thing in alisp, I need some time ,I think.
« Last Edit: April 10, 2014, 09:17:11 PM by beverage »
owenwengerd
« Reply #3 on: April 10, 2014, 09:48:01 PM »
AutoCAD and Bricscad may work differently in that regard.
beverage
« Reply #4 on: April 10, 2014, 10:27:06 PM »
thank you, owenwengerd!
Sorry, I didn't heard about Bricscad , I and my team use AutoCAD all the time.
we discus both Bricscad and AutoCAD here? or only Bricscad ?
apology for my bad english.
I did some further test ,
When I using the
  1. (ssget '((0 . "LWPOLYLINE")  (10 47045.6 62081.2)))
It didn't work too, so I guess not only one group code can't be used in ssget fliter
« Last Edit: April 10, 2014, 10:30:43 PM by beverage »
roy_043
  • BricsCAD 18
« Reply #5 on: April 11, 2014, 03:59:14 AM »
For obvious reasons I keep forgetting to mention that. Thanks.
owenwengerd
« Reply #6 on: April 11, 2014, 09:41:50 AM »
Both are discussed here, and most Lisp code works the same in both, but not always. This just happens to be a case where the platform matters.
« Reply #7 on: April 12, 2014, 09:05:50 AM »
You could alternatively use the following ssget filter list to include only Aligned dimensions:
    (0 . "DIMENSION")
    (-4 . "<OR")
        (70 . 001)
        (70 . 033)
        (70 . 065)
        (70 . 097)
        (70 . 129)
        (70 . 161)
        (70 . 193)
        (70 . 225)
    (-4 . "OR>")
roy_043
  • BricsCAD 18
« Reply #8 on: April 12, 2014, 01:39:20 PM »
Or:
(ssget "_A" ((0 . "DIMENSION") (-4 . "&") (70 . 1)))
« Reply #9 on: April 12, 2014, 02:05:13 PM »
Or:
Unfortunately, DXF group 70 for dimensions is not truly bit-coded - I believe your code would also select Diameter & Angular 3-Point dimensions, in addition to Aligned dimensions.
« Reply #10 on: April 12, 2014, 02:44:56 PM »
For a more functional approach, perhaps something like:
(defun dim-filter ( typ )
    (append
       '((0 . "*DIMENSION") (-4 . "<OR"))
        (mapcar '(lambda ( x ) (cons 70 (+ typ x))) (bit-combinations '(32 64 128)))
       '((-4 . "OR>"))
(defun bit-combinations ( l / foo bar )
    (defun foo ( l r )
        (if (and l (< 1 r))
            (append (mapcar '(lambda ( x ) (+ (car l) x)) (foo (cdr l) (1- r))) (foo (cdr l) r))
            l
    (defun bar ( l r )
        (if (< 0 r) (append (bar l (1- r)) (foo l r)))
    (cons 0 (bar l (length l)))
Hence, for aligned dimensions:
_$ (dim-filter 1)
((0 . "*DIMENSION") (-4 . "<OR") (70 . 1) (70 . 33) (70 . 65) (70 . 129) (70 . 97) (70 . 161) (70 . 193) (70 . 225) (-4 . "OR>"))
kruuger
« Reply #11 on: April 12, 2014, 04:49:56 PM »
    (append
       '((-4 . "OR>"))
    (defun foo ( l r )
        (if (and l (< 1 r))
            l
    (defun bar ( l r )
_$ (dim-filter 1)
interesting :) is it possible to get only Rotated dims ?
thanks
kruuger
« Reply #12 on: April 12, 2014, 05:22:51 PM »
Thanks kruuger  :-)
For Rotated Dimensions, you should be able to use:
(ssget (dim-filter 0))
Reference
kruuger
« Reply #13 on: April 12, 2014, 05:47:03 PM »
Thanks kruuger  :)
Reference
A W E S O M E !!! I can improve my few tools.
thank you
kruuger
« Reply #14 on: April 12, 2014, 06:39:51 PM »
thank you
kruuger
You're most welcome kruuger!  :-)
