Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
File size increases for no apparent reason
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: File size increases for no apparent reason (Read 6224 times)
Nardino
Newt
on:
April 09, 2014, 03:01:22 PM »
Hello everybody, I have here a small dilemma. I have many files from our subs that range in size from 1200kb to 1500kb. As i save these files into our network, for no apparent reason they increase to around 8500kb. I am not drawing anything nor adding anything to these drawings.....just resaving them....Any ideas??
thanks...Nardino
Logged
Jeff H
Needs a day job
Re: File size increases for no apparent reason
Reply #1 on:
April 09, 2014, 03:04:31 PM »
Is it getting saved to a newer version or saved with a vertical?
Logged
--> Donate to TheSwamp <--
Nardino
Newt
Reply #2 on:
April 09, 2014, 03:08:23 PM »
same acad version...2013
Logged
Seagull
Every Student their own Lesson
WWW
Reply #3 on:
April 09, 2014, 03:57:13 PM »
are you decompressing zipped files?
Logged
Nardino
Newt
Reply #4 on:
April 09, 2014, 03:59:48 PM »
yes, I did received them as a zipped file and the size of each one unzipped was as I mentioned around 1200kb.
Logged
cadtag
Swamp Rat
Reply #5 on:
April 09, 2014, 04:09:10 PM »
are you opening the drawings after unzipping, and then saving them?
If you are running a vertical, AA , C3D, etc, they will add to the file size automatically with AEC data.
Logged
Crank
Water Moccasin
Reply #6 on:
April 09, 2014, 04:14:01 PM »
ISAVEPERCENT = 0
SAVEFIDELITY = 0
Logged
Vault Professional 2023 + AEC Collection
Nardino
Newt
Reply #7 on:
April 09, 2014, 04:21:43 PM »
I am not doing anything to these files........basically unzip them and resave them in our network. They were created in AutoCad 2013 and resaved in with the same version
Logged
Nardino
Newt
Reply #8 on:
April 09, 2014, 04:40:44 PM »
ISAVEPERCENT = 0, and SAVEFIDELITY = 0............already set to these values
Logged
Rob...
King Gator
Take a little time to stop and smell the roses.
Reply #9 on:
April 09, 2014, 04:57:06 PM »
Can you purge anything out of them?
How about sharing one of the files before it gets bloated?
Logged
CAD Tech
Nardino
Newt
Reply #10 on:
April 09, 2014, 05:18:58 PM »
Everything is purged.
I am enclosing 3 drawings here in a zipped file. One is a duplicate after i resaved it and the filesize increased, and the other is nothing more than a titleblock. The file to compare is: NHMCT111-500-A4-P0410-00T.dwg and zzzNHMCT111-500-A4-P0410-00T.dwg.
thanks
Logged
Seagull
Have thousands of dwgs to process? Contact me.
WWW
Reply #11 on:
April 09, 2014, 05:37:19 PM »
Very brief examination of the patient reveals the dwg needs JennyCraig.lsp because it's morbidly bloated with zombies and regapp entries likely introduced by an audit. Sorry, way too busy to provide more info.
Logged
cadanalyst@gmail.com
http://cadanalyst.slack.com
http://linkedin.com/in/cadanalyst
Seagull
WWW
Reply #12 on:
April 09, 2014, 07:43:32 PM »
I'm curious why are you opening them to re-save them at all?
I mean if someone send me a zip file full of files I don't open those files to save them where they belong on the network.
While that still wont get rid of the junk in the files as mentioned above, in theory it also wont create it either.
Logged
Seagull
WWW
Reply #13 on:
April 09, 2014, 07:47:54 PM »
Many companies quarentine and clean externally supplied drawings before making them available for internal use. The implementation I use may differ from the OP's but the principle is sound IMO.
Logged
Nardino
Newt
Reply #14 on:
April 10, 2014, 09:04:10 AM »
I need to resave them because I add a transmittal date
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
