jar,
.. Autolisp Command?
I do not have the BRX|bricsys TX SDK's , do you have the BRX or the bricsys TX SDK's?
I don't have it, but could probably find it on the web.
I am a complete newbie when it comes to Bricsys but they seem
to recommend going with the BRX SDK's as it is supposed to be completely
compatible with ARX.
You need to register as a developper here
http://www.bricsys.com/bricscad/help/en_US/V14/DevRef/index.html?page=source%2FBRX_01.htm in order to download the SDK.
However a little reading on their site states that the SDK is not compatible with "Classic" you need "Pro"
or "Platinum" .
Furthermore some of the required dll are part of the Bricscad installation. Seems like you need Bricscad
installed on your system in order to develop for it.
I believe you are right, there is no other way than having an interface to a library (For example "libpng").
You also need "zlib" as libpng is dependent on it.
ymg
