Author Topic: Replacing block without changing attribute  (Read 3015 times)
TJAM51
« on: April 06, 2005, 10:37:42 AM »
I have a block named 1a. This block has an attribute with information typed into the attribute. I need to replace this block 1a with a new block 2a but need to retain the attribute information...only the physical block shape and size are affected......any ideas?
David Hall
  • Automatic Duh Generator
« Reply #1 on: April 06, 2005, 11:14:49 AM »
What happens if you redefine 1a = 2a?  I think the block will update as long as the Attributes are the same.  Can you post the 2 blocks and we can test it?
hudster
« Reply #2 on: April 06, 2005, 11:23:25 AM »
if the attributes are the same, can you export them from block a and import to block b?
« Reply #3 on: April 06, 2005, 11:36:28 AM »
If all you are doing is changing the way the block looks by redefining it, the attribute values should stay the same. Post the drawing you are working on.
Ron
« Reply #4 on: April 06, 2005, 11:36:38 AM »
Here is one I use quite regularly
;;;   UB.LSP
;;;   Copyright (C) 1997-2005 by K.E. Blackie
;;;   kblackie -AT- resourcecad.com
;;;   Permission to use, copy, modify, and distribute this software
;;;   for any purpose and without fee is hereby granted, provided
;;;   that the above copyright notice appears in all copies and that
;;;   both that copyright notice and this permission notice appear in
;;;   all supporting documentation.
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;;   15 March 1997
;;;   8 August 1998
;;;   29 November 2001
;;;   12 January 2005
;;;   DESCRIPTION
;;;   C:UB
;;;   This function replaces a block reference specified by the user
;;;   to another block already inserted in the drawing.
;;;   All attributes are left in place and remain unmodified.
;;;   No error checking is provided. It is presumed the user will
;;;   know what blocks are already inserted and available for use.
(DEFUN C:UB( / as e index newname ss ssl)
  (setq ss (ssget '((0 . "insert"))))
  (setq newname (getstring t "\nReplace with block name: "))
  (setq ssl(sslength ss))
  (setq index 0)
  (repeat ssl
   (setq e (entget(ssname ss index)))
   (setq as (assoc 2 e))
   (setq e (subst (cons 2 newname) as e))
   (entmod e)
   (setq index (+ 1 index))
 (PRINC)
CottageCGirl
« Reply #5 on: April 06, 2005, 12:09:53 PM »
copy the block- explode the copy, edit the shape-make the revised one back into a block of the same name (be sure to select a base point) -click ok and the origional  will be redefined  [by copying it, it is a double check that it works-you just erase the duplicate when you are done]
this will work for all of the same blocks in a drawing
dubb
« Reply #6 on: April 06, 2005, 01:24:16 PM »
cant you also use the "refedit" command?
VerticalMojo
« Reply #7 on: August 11, 2005, 10:56:52 AM »
Keith, is there a way to use your lisp but have it ask for the block name instead of selecting objects that way you can globally do a change?
« Reply #8 on: August 11, 2005, 11:28:46 AM »
Should be able to be done easily enough ... If I get some time, I'll look at it ... kinda busy right now ...
Bob Wahr
« Reply #9 on: August 11, 2005, 11:32:48 AM »
-insert 1a=2a
or if you need the name to change as well, use rename to rename 1a to 2a then -insert 2a=
Amsterdammed
« Reply #10 on: August 11, 2005, 02:54:44 PM »
Bob,
that's a cool one.
There are always thinks in Acad i don't know about yet.
Thanks,
Bernd
