Author Topic: ** Error: no function definition: VLA-GET-OBJECTID32 **  (Read 12968 times)
Re: ** Error: no function definition: VLA-GET-OBJECTID32 **
« Reply #15 on: April 10, 2014, 01:43:49 PM »
Give this version a try .. seems to be working on my computer. I noted the change in the header.
Ron -
As noted, I unfortunately don't have access to a 64-bit system to test, so I was curious: based on your modifications to the code, does the setblocktablerecordid32 accept a string representation of the 64-bit object ID (as returned by the getobjectidstring method)?
Also, why is the (= (type vla-get-objectid32) 'subr) test not sufficient to cater for 2014 onwards?
Many thanks,
Lee
« Reply #16 on: April 10, 2014, 03:02:23 PM »
Lee,
From my testing, the setblocktablerecordid32 chucks a wobbly with the x64 objectID string.
_$
_1$
'(vlax-invoke #<VLA-OBJECT IAcadTable 000000002e0bd7f8> SETBLOCKTABLERECORDID32 2 0 "140700197868736" :vlax-true)
_1$
** Error: Out of present range **; reset after error
This test is fine (= (type vla-get-objectid32) 'subr) ... perhaps the function below will suffice :)
(defun _getobjectid (doc obj)
  (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
    (if (= (type vla-get-objectid32) 'subr)
      (vla-get-objectid32 obj)
      (vlax-invoke-method (vla-get-utility doc) 'getobjectidstring obj :vlax-false)
    (vla-get-objectid obj)
HTH.
« Reply #17 on: April 12, 2014, 08:37:46 AM »
Many thanks Ron  :-)
Rabbit
« Reply #18 on: April 24, 2014, 06:12:41 PM »
So will adding Ron's routine and using (_getobjectid docblocks a) instead of (vla-get-objectid32 a) in my routine below work?
    (if (and (_is64bit) (= (type vla-get-objectid32) 'subr))
(setq My_block (cdr (assoc 2 (entget FreshInsertedBlock))))
      (setq docblocks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
      (setq a (vla-item docblocks My_block))
      (setq BlockObjectID (vla-get-objectid32 a))
« Reply #19 on: April 24, 2014, 06:44:59 PM »
Been a long week so I may be overlooking something, but this is the way my brain's working today:
(defun _GetObjectID ( object )
    (if vla-get-objectid32
        (defun _GetObjectID ( object ) (vla-get-objectid32 object))
        (defun _GetObjectID ( object ) (vla-get-objectid object))
    (_GetObjectID object)
tl;dr: Test once, and only as much as is req'd.
« Reply #20 on: April 24, 2014, 07:21:30 PM »
If one prefers the obfuscated:
    (eval
        (cons 'defun
            (cons '_GetObjectID
                (list '(object)
                    (list
                        (if vla-get-objectid32 'vla-get-objectid32 'vla-get-objectid)
                        'object
« Reply #21 on: April 24, 2014, 07:36:56 PM »
I'm sure there is one.
« Reply #22 on: April 24, 2014, 07:45:07 PM »
lolz
Rabbit
« Reply #23 on: April 25, 2014, 09:05:47 AM »
The "obfuscated" version worked great in 2012.  Since I don't have 2015, and I'm helping someone who does, I'll get back with you on if it works there.  Many thanks.
« Reply #24 on: April 25, 2014, 09:14:02 AM »
You're welcome and thanks for letting me know -- I wrote it under 2010 -- conceptually it should work for 2015 -- but it's merely a guess.
« Reply #25 on: April 25, 2014, 09:16:17 AM »
An aside -- is Rabbit the same person that used to post in the Take 5 forum with David Doane and crew a million years ago?
« Reply #26 on: April 25, 2014, 09:49:08 AM »
Another variant for fun (penned under 2011, appears to work fine):
    (eval
        (list 'defun '_GetObjectID '(object)
            (list
                'object
owenwengerd
« Reply #27 on: April 25, 2014, 10:21:56 AM »
Yes, and both are still posting. You should stop by and say "hello".
« Reply #28 on: April 25, 2014, 10:27:24 AM »
Wow. Didn't know it was still active. Can you pm me the link Owen? Thanks so much for letting me know. tl;dr: I feelz old now.
« Reply #29 on: April 25, 2014, 11:19:28 AM »
FWIW .. Michael's version breaks Lee's code in AutoCAD 2015 x64. Don't have an x86 computer to test on.
(setq o (vlax-ename->vla-object (car (entsel))))
#<VLA-OBJECT IAcadLWPolyline 000000f2812dbb28>
MP_GETOBJECTID
1055
RJP_GETOBJECTID
"140694991308416"
Apparently vla-setblocktablerecordid will accept an integer or string.
