Author Topic: ** Error: no function definition: VLA-GET-OBJECTID32 **  (Read 12853 times)
KuoTze
  • Mosquito
« on: April 01, 2014, 08:32:17 AM »
i work in AutoCad 2015 and run "LeeMAC's CountV1-3.lsp" but it error and msg is ** Error: no function definition: VLA-GET-OBJECTID32 **
How can Fix it ......
Sorry i English is not good to say ~~ please forgive ~~  :embarrassed:
Re: ** Error: no function definition: VLA-GET-OBJECTID32 **
« Reply #1 on: April 01, 2014, 08:49:40 AM »
The function is obsolete.
I'm not sure how or why it is being used.
Can you test/try the code using VLA-GET-OBJECTID
KuoTze
  • Mosquito
« Reply #2 on: April 01, 2014, 09:04:13 AM »
 :embarrassed:
i try to fix "vla-get-objetcid32 to vla-get-objetcid"
but can't work and Msg ** Error: ActiveX Server returned the error: unknown name: "SETBLOCKTABLERECORDID32" **
So .... i can't fix it ........
« Last Edit: April 01, 2014, 09:18:11 AM by KuoTze »
« Reply #3 on: April 01, 2014, 09:18:06 AM »
Change the function to this:
(defun _getobjectid (doc obj)
    (if   (and (_is64bit) (= (type vla-get-objectid32) 'subr))
      (vla-get-objectid32 obj)
      (vla-get-objectid obj)
And change this portion of the code:
                (if (and (_is64bit)
                    (= (type vla-setblocktablerecordid32) 'subr)
                  'setblocktablerecordid32
Welcome to TheSwamp :)
« Last Edit: April 01, 2014, 09:24:28 AM by ronjonp »
KuoTze
  • Mosquito
« Reply #4 on: April 01, 2014, 09:27:26 AM »
 :-) thank ...
i paste your code to lisp it can't work and msg ** Error: ActiveX Server returned the error: unknown name: "SETBLOCKTABLERECORDID32" **
so ......................
KuoTze
  • Mosquito
« Reply #5 on: April 01, 2014, 10:00:55 AM »
thank your code
(if (and (_is64bit)
but ......
now error msg is :
Output [Table/File/Settings] <Exit>:
Specify Point for Table: ; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
it can't work   :embarrassed:
« Reply #6 on: April 01, 2014, 11:42:35 AM »
Give this version a try .. seems to be working on my computer. I noted the change in the header.
KuoTze
  • Mosquito
« Reply #7 on: April 01, 2014, 12:32:32 PM »
Thank you so much  ...........
Count1.31-RJP can work
 :lmao: :lmao: :lmao:
« Reply #8 on: April 01, 2014, 12:34:31 PM »
Glad to help  :)
« Reply #9 on: April 01, 2014, 06:05:26 PM »
Many thanks Ron -
I don't have a 64-bit system on which to test the program, so I am incredibly grateful for your assistance.
Lee
« Reply #10 on: April 01, 2014, 06:10:34 PM »
Hi Kerry,
I wasn't aware that this function had become obsolete in 2015.
Thank you for the information.
Lee
« Reply #11 on: April 01, 2014, 09:04:40 PM »
It was marked Obsolete in the 2014 Help. I can't confirm 2015 yet.
« Reply #12 on: April 01, 2014, 09:29:57 PM »
Many thanks Ron -
Lee
Anytime Lee :) .. you've helped me a ton.
« Reply #13 on: April 01, 2014, 09:31:18 PM »
Installed 2015 a week ago and that function is gone.
Hugo
« Reply #14 on: April 02, 2014, 12:38:02 AM »
Hallo Lee
Here I have ever asked is that no longer work in 2015.  :-D
Hier habe ich schon mal gefragt das das nicht mehr funktionieren wird in 2015.
http://www.theswamp.org/index.php?topic=33654.msg513336#msg513336
