Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Geometric Constraints
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Geometric Constraints (Read 2201 times)
GDF
Water Moccasin
on:
March 28, 2014, 10:30:53 AM »
I am looking for a way to disable AutoCAD's Geometric Constraints and to delete all existing Constraints through lisp if that is possible each time I open a drawing.
Would this be my approach (setvar "CONSTRAINTSOLVEMODE" 0)?
Logged
GDF
Water Moccasin
Re: Geometric Constraints
Reply #1 on:
April 01, 2014, 10:57:26 AM »
I found what I was looking for...To turn off the "Infer Geometric Constraints" toggle within the Constraint Settings dialog box in the Parametric menu pull down.
I guess my question is how to toggle this setting off thru lisp.
Logged
PKENEWELL
Bull Frog
Reply #2 on:
April 01, 2014, 01:39:48 PM »
Try This:
Code:
[Select]
(setvar "CONSTRAINTINFER" 0)
Logged
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
GDF
Water Moccasin
Reply #3 on:
April 01, 2014, 03:56:14 PM »
Thank you, that did it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
