Author Topic: Must Recompile for AutoCAD 2015  (Read 4833 times)
cmwade77
« on: March 27, 2014, 04:58:02 PM »
Several people here probably already know this, but I think it's important to mention, as it is completely unexpected to have this happen with this release.
So, please note that while AutoCAD 2015 does not have a file format change, there is an API change which requires ARX files to be recompiled for 2015. There have also been several other changes, so you may find that you also have to rework some of your code.
Re: Must Recompile for AutoCAD 2015
« Reply #1 on: March 27, 2014, 05:01:51 PM »
Do you have a reliable reference source for your post ?
I was wondering about the sanctioned use of VS2013 also ... s'pose I should read the docs :)
--> Donate to theSwamp<--
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: March 28, 2014, 12:34:42 AM »
I read somewhere they were itching to move to VS2012 for 2014, but caved to complaints from thirdparty devs.  I wonder if they made the jump to a newer compiler or just introduced breaking changes.
Retired
owenwengerd
« Reply #3 on: March 28, 2014, 12:43:11 AM »
They went to VS 2012.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: March 28, 2014, 03:27:22 AM »
Thanks Owen  :-)
Retired
