Author Topic: C3D 2013: Missing Dialogs in Bedit and Refedit  (Read 3050 times)
alanjt
  • Standby for witty remark...
« on: March 27, 2014, 12:57:38 PM »
In Civil 3D 2013, if I execute refedit or bedit, I don't have any dialogs, or contextual ribbon tabs. In refedit, I don't mind so much, since I can just type 'refclose' when finished, but in bedit, I don't have access to the block editing palette, or a way to change visibility states when editing a dynamic block.
Has anyone encountered this? Do I just have some weird sysvar turned off?
Dropbox
Crank
Re: C3D 2013: Missing Dialogs in Bedit and Refedit
« Reply #1 on: March 28, 2014, 02:28:22 PM »
Just guessing: RIBBONCONTEXTSELLIM
alanjt
« Reply #2 on: March 28, 2014, 02:48:20 PM »
Nope.  :cry:
I can't figure out what it might be. It wouldn't be so bad, but I need the toolbars/palette for BEdit.
Dropbox
Crank
« Reply #3 on: March 28, 2014, 04:13:57 PM »
You can also try RIBBONCONTEXTSELECT
BlackBox
« Reply #4 on: March 28, 2014, 04:19:25 PM »
I am unable to duplicate the behavior you're experiencing (using C3D 2014)
alanjt
« Reply #5 on: March 28, 2014, 04:26:31 PM »
All turned on.
I don't get it. arg.
Dropbox
« Reply #6 on: March 28, 2014, 04:33:37 PM »
suggest opening the Block Editor then try "RIBBON"
or
while in Block Editor
-toolbar command
alanjt
« Reply #7 on: March 28, 2014, 04:54:44 PM »
or
-toolbar command
My ribbon and toolbars are visible.
Even when I tell it to turn on all toolbars, the block/ref edit toolbars are not visible and the ribbon is still the same.
My dynamic block palette is displaying now, but I still don't have access to the visibility state pulldown. Strangeness.
Dropbox
« Reply #8 on: March 28, 2014, 05:55:58 PM »
you not running dashboard are you?
my quick search said they do not work well together and will exhibit these and or other symptoms
