Author Topic: Verify the number from user's input  (Read 4830 times)
Re: Verify the number from user's input
« Reply #15 on: March 21, 2014, 04:06:41 PM »
Sorry, I should give more details. Here is the portion of my code:
(getreal "\nEnter the number: ")
This means that the user can enter an integer or a real nember.
I don't want to give the user to choose the type of input by using both "getreal" and "getini" in the code.
I believe the confusion in this thread arises because ℤ ⊂ ℝ, that is the set of integers is contained in the set of real numbers - hence by prompting the user for a real number, they are also permitted to enter an integer.
I'm also unsure what you are trying to achieve, but here is my offering for darts game:
  1. (defun getreal-or-int ( msg / dim num )
  2.     (if (setq num (getreal msg))
  3.         (progn
  4.             (setq dim (getvar 'dimzin))
  5.             (setvar 'dimzin 8)
  6.             (setq num (read (rtos num 2 15)))
  7.             (setvar 'dimzin dim)
  8.         )
  9.     )
  10.     num
  11. )
  1. Command: (getreal-or-int "\nEnter a number: ")
  2. Enter a number: 2
  3. 2
  4.
  5. Command: (getreal-or-int "\nEnter a number: ")
  6. Enter a number: 2.0
  7. 2
  8.
  9. Command: (getreal-or-int "\nEnter a number: ")
  10. Enter a number: 2.5
  11. 2.5
Hopefully I'll hit the treble-20  8-)
GP
  • Vercelli, Italy
« Reply #16 on: March 22, 2014, 10:26:08 AM »
darts game 2.0   :-)
(if (zerop (- num (fix num))) (atoi (rtos num)) num)
2    ->  2
2.0  ->  2
2.5  ->  2.5
« Reply #17 on: March 22, 2014, 10:31:18 AM »
@GP, you might need to use (atoi (rtos num 2))  ;-)
gile
  • Marseille, France
« Reply #18 on: March 22, 2014, 02:33:15 PM »
No need to convert to string and convert back:
  1. (defun getRealOrInt (msg / num int)
  3.     (if (= (setq int (fix num)) num)
  4.       int
  5.       num
  6.     )
  7.   )
  8. )
« Reply #19 on: March 22, 2014, 02:50:14 PM »
  4.       int
  5.       num
  6.     )
  7.   )
  8. )
Very elegant gile.
gile
  • Marseille, France
« Reply #20 on: March 22, 2014, 04:14:22 PM »
Thanks Kerry, but it wasn't so difficult  :wink:
GP
  • Vercelli, Italy
« Reply #21 on: March 23, 2014, 06:54:41 AM »
True...
thanks.  :-)
MeasureUp
« Reply #22 on: March 23, 2014, 07:17:51 PM »
WOW! It's amazing. I just come back from a buzy time.
Thanks to everyone.
This is my proposal:
(setq UserInput (getreal "\nEnter the number: "))
(if (UserInput is an integer)
    (Option 1 ...)
   (progn (Get_Number_of_Decimal) ;;; if the input is a real"
         (Option 2 ...)
Kerry, hope your football term wins next time.
NICK_VNV & CAD, your codes are simple and straightforward.
(setq a (getreal "\nEnter the number: "))
(if (> (rem a 1) 0)
  (setq typ "REAL")
  (setq typ "INT")
(princ (strcat "\nEntered type is " typ))
;; get precision of a decimal number string including trailing zeros
  (defun getPrec (str)
    (if (vl-string-search "." str)
      (- (strlen str)(vl-string-search "." str) 1)
      0
gile, your are so smart!
Lee, you always think something different from others.
You did not waste your time. I can learn from your ideas.
Thanks to swamp people.  :-) :-) :-)
« Last Edit: March 24, 2014, 01:06:50 AM by MeasureUp »
Peter2
« Reply #23 on: July 27, 2014, 10:55:53 AM »
  4.       int
  5.       num
  6.     )
  7.   )
  8. )
Hi
maybe I missed something, but using this code I get:
  1. Befehl: (getrealorint "2.0")
  2. 2
  3. nil
It seems that "getreal" needs a "real user input" and not only a value??
Peter
BricsCAD V23
« Reply #24 on: July 27, 2014, 11:32:52 AM »
Here using 2006ACAD I get 2
It will accept 2 or 2.0
Peter2
« Reply #25 on: July 27, 2014, 11:52:25 AM »
You mean "2" or "2.0", right?
Peter
BricsCAD V23
« Reply #26 on: July 27, 2014, 12:01:16 PM »
Note that the argument passed to gile's function is the prompt string to be displayed to the user for the getreal function, not the value to be interpreted.
Peter2
« Reply #27 on: July 29, 2014, 04:25:18 AM »
Ooh - I see. Thank you.
Peter
BricsCAD V23
