Author Topic: Verify the number from user's input  (Read 4820 times)
MeasureUp
« on: March 20, 2014, 09:28:17 PM »
How to verify a user's input is an integer or a real number?
Then how to check the number of decimal digits if the user's input is a real number?
Thanks for your help.
Re: Verify the number from user's input
« Reply #1 on: March 20, 2014, 10:52:45 PM »
Sometimes personal Library functions are handy :)
If you're concerned about input ask for the type you want.
  1. (setq i1 (getint "Specify Integer number value"))
  2. (setq r1 (getreal "Specify Real number value"))
If you have the date data , check if it's a number
  1. (setq integer    4)
  2. (setq real       5.1)
  3. (setq edgecase   6.0)
  4. (setq real-4Places1 4.1111)
  1. (and (numberp integer)
  2.      (numberp real)
  3.      (numberp edgecase)
  4.      (numberp real-4Places1)
  5. )
  6.
If it's a number, check it's type
  1. (defun kdub:real-p (arg)  (equal (type arg) 'real))
  2. (defun kdub:integer-p (arg)  (equal (type arg) 'int))
If it's a real, check the decimal places.
  1. (defun kdub:decimalPlaces (nval)
  2.   (if (zerop (rem nval 1))
  3.     0
  4.     (- (strlen (vl-prin1-to-string (rem nval 1))) 2)
  5.   )
  6. )
  1. (kdub:decimalPlaces integer)       ;=> 0
  2.
  3. (kdub:decimalPlaces real)          ;=> 1
  4. (kdub:decimalPlaces real-4Places1) ;=> 4
  5. (kdub:decimalPlaces edgecase)      ;=> 0
  6.
  7.
« Last Edit: March 21, 2014, 09:11:44 AM by Kerry »
MeasureUp
« Reply #2 on: March 21, 2014, 12:27:24 AM »
Sorry, I should give more details. Here is the portion of my code:
(getreal "\nEnter the number: ")
This means that the user can enter an integer or a real nember.
I don't want to give the user to choose the type of input by using both "getreal" and "getini" in the code.
« Reply #3 on: March 21, 2014, 01:53:18 AM »
You just need to think sideways for a second.
  1. ;;an absurdity: kdub@theSwamp
  2.
  3. (defun _getreal (promptmsg / returnvalue)
  4.         (setq returnvalue (vl-catch-all-apply 'getreal (list promptmsg)))
  5.       )
  6.     ;; ESC was pressed.
  7.     (setq returnvalue nil)
  8.   )
  9.   (if returnvalue
  10.     (float returnvalue)
  11.     nil
  12.   )
  13. )
  14.
  15.
  16. (_getreal "Specify Real number value")
  17.
  18.
Perhaps I should explain that this code is a JOKE.
MeasureUp,
You have obviously done no testing with the code I posted.
Please explain how
  1. (setq nVar (getreal "\nEnter the number: "))
can accept anything other than a real number.
What is the value of nVar if you respond to the prompt with the integer 42 ??
« Last Edit: March 21, 2014, 02:36:50 AM by Kerry »
Marc'Antonio Alessi
  • Marco
« Reply #4 on: March 21, 2014, 04:19:35 AM »
an example:
; BitVal values:
; 0 - only number
; 1 - reject positive (and zero)
; 2 - reject zero
; 4 - reject negative
; 8 - reject real, must be integer
; value 3 is equal to 1
; value 11 is equal to 9
; values 5, 7, 13, 15 not have sense > rejects all values
; ex: (ALE_CheckNumber -1 6 nil nil)
(defun ALE_CheckNumber (ImpVal BitVal FrmVal ToVal / ErrStr)
    ( (or
        (not (numberp ImpVal))                                 ; not number
        (and (= 1 (logand 1 BitVal)) (= (abs ImpVal)  ImpVal)) ; is positive
        (and (= 2 (logand 2 BitVal)) (zerop ImpVal))           ; is zero
        (and (= 4 (logand 4 BitVal)) (/= (abs ImpVal) ImpVal)) ; is negative
        (and (= 8 (logand 8 BitVal)) (= 'REAL  (type ImpVal))) ; is real, not int
        (and FrmVal ToVal      (not (<= FrmVal ImpVal ToVal))) ; not in range
        ( (= BitVal  1) (setq ErrStr "The number must be negative") )
        ( (= BitVal  2) (setq ErrStr "The number must be different from zero") )
        ( (= BitVal  4) (setq ErrStr "The number must be positive or zero") )
        ( (= BitVal  8 ) (setq ErrStr "The number must be integer") )
        ( (= BitVal  6) (setq ErrStr "The number must be positive and different from zero") )
        ( (= BitVal  9) (setq ErrStr "The number must be integer negative") )
        ( (= BitVal 10) (setq ErrStr "The number must be integer and different from zero") )
        ( (= BitVal 12) (setq ErrStr "The number must be integer positive or zero") )
        ( (= BitVal 14) (setq ErrStr "The number must be integer positive and different from zero") )
        ( T             (setq ErrStr "Value must be a number") )
      (if (and FrmVal ToVal)
        (setq ErrStr (strcat ErrStr " and inclusive among " (ALE_RtoS_DZ8 FrmVal) " and " (ALE_RtoS_DZ8 ToVal) "!"))
        (setq ErrStr (strcat ErrStr "!"))
    ( ImpVal )
(defun ALE_RtoS_DZ8 (ReaVal / CurDZn OutVal)
  (if (= 8 (setq CurDZn (getvar "DIMZIN")))
    (setq CurDZn nil)
    (setvar "DIMZIN" 8 )
  (setq OutVal (rtos ReaVal 2))
  (and CurDZn (setvar "DIMZIN" CurDZn))
  OutVal
NICK_VNV
« Reply #5 on: March 21, 2014, 05:06:45 AM »
Check if my code can help you
(setq a (getreal "\nEnter the number: "))
(if (> (rem a 1) 0)
  (setq typ "REAL")
  (setq typ "INT")
(princ (strcat "\nEntered type is " typ))
And then
  3.     0
  5.   )
  6. )
(kdub:decimalPlaces a)
« Last Edit: March 21, 2014, 05:18:16 AM by NICK_VNV »
Sorry for my English...
« Reply #6 on: March 21, 2014, 05:24:00 AM »
This means that the user can enter an integer or a real number.
I don't want to give the user to choose the type of input by using both "getreal" and "getint" in the code.
MeasureUp,
You may need to restate your requirements.
What input do you want from the user ?
Do you want to use getReal() for decimal numbers ?
Do you want to use getInt() for integer numbers ?
or do you want to do something else like getAnyNumber() for a particular reason ?
If that is the case do you need to know the type? and why ?
A little more information at the start would make resolving your problem possible.
« Last Edit: March 21, 2014, 05:32:01 AM by Kerry »
« Reply #7 on: March 21, 2014, 07:30:38 AM »
Shot in the dark-
The Op wants to interpret user input from getstring as a number (my idea)
If no decimal is used the input is integer.
If decimal then how many places entered.
snownut2
  • Bricscad 22 Ultimate
« Reply #8 on: March 21, 2014, 07:46:50 AM »
CAB,
According to OP's second post he is using a "Getreal" function to retrieve user input, apparently he does not believe its a real number if user enters non-decimal input.
« Reply #9 on: March 21, 2014, 07:56:36 AM »
I'm just saying that if you want the number of trailing zeros you need to use getstring and convert to a number.
And use this on the string.
  ;; get precision of a decimal number string including trailing zeros
  (defun getPrec (str)
    (if (vl-string-search "." str)
      (- (strlen str)(vl-string-search "." str) 1)
      0
« Reply #10 on: March 21, 2014, 07:57:54 AM »
You never know exactly what the OP wants until you get "That's it" from the OP. 8)
It's quite a dart game answering some of these questions.
« Reply #11 on: March 21, 2014, 08:50:39 AM »
I'm not quite so generous Alan.
Solving the problem is usually time consuming ... solving the question is a bloody waste of good time.
and my football team lost tonight so I'm not happy anyway .. but at least they tried.
Marc'Antonio Alessi
  • Marco
« Reply #12 on: March 21, 2014, 08:53:43 AM »
maybe this:
; ---------- Source files from: --------------------------------------------
; These functions are freeware courtesy of the author's of "Inside AutoLisp"
; for rel. 10 published by New Riders Publications. This credit must
; accompany all copies of this function.
; Modified by Alessi Marc'Antonio
; UINT   Funzione di interfaccia utente per numeri interi.
; IGtBit > (0 for none) and KwdStr key word ("" for none) same of INITGET
; PrmStr = prompt string, a default integer will be added
;          as <DefInt> (nil for none) and a : will be added
; Example:
; (setq #GlVal (uInt 7 "" "How many times" #GlVal))
(defun uInt (IGtBit KwdStr PrmStr DefInt / InpVal)
  (if DefInt
    (setq PrmStr (strcat "\n" PrmStr " <" (itoa DefInt) ">: ")
          IGtBit (logand IGtBit 254)
    (setq PrmStr (strcat "\n" PrmStr ": "))
  (initget IGtBit KwdStr)
  (setq InpVal (getint PrmStr))
  (if InpVal InpVal DefInt)
; UREAL  Funzione di interfaccia utente per numeri reali.
; PrmStr = prompt string, a default real will be added
;          as <DefRea> (nil for none), a : will be added.
; Example:
; (setq #GlVal (uReal 1 "" "Scale factor" #GlVal))
(defun uReal (IGtBit KwdStr PrmStr DefRea / InpVal)
  (if DefRea
    (setq
      PrmStr (strcat "\n" PrmStr " <" (ALE_RTOS_DZ8 DefRea) ">: ")
  (setq InpVal (getreal PrmStr))
  (if InpVal InpVal DefRea)
;ALE_RTOS_DZ8 see previous post
« Reply #13 on: March 21, 2014, 09:02:23 AM »
That's a familiar blast from the past. :)
Marc'Antonio Alessi
  • Marco
« Reply #14 on: March 21, 2014, 09:12:43 AM »
   ...if I remember correctly it was around 1990... I continue to use it again!
