Author Topic: A person who shall remain nameless ...  (Read 19762 times)
David Hall
  • Automatic Duh Generator
« Reply #15 on: April 08, 2005, 10:57:22 AM »
I DL and tried, and it appears to work when I start acad, in that it turns caplock on.  When I click/alttab toa browser, it turns it off.  BUT when I give acad focus, it does not turn it back on.  I checked both boxes in the setup. Was that right?
BTW, I have this code that does the same thing that Se7en is suggesting, in that my code turns on caps for text commands.
Option Explicit
Private WithEvents AutoCAD As AcadApplication
'Begin Code Block
Private Const VK_CAPITAL = &H14
Private Type KeyboardBytes
     kbByte(0 To 255) As Byte
End Type
Private kbArray As KeyboardBytes
Private Declare Function GetKeyState Lib "user32" _
() '   (ByVal nVirtKey As Long) As Long
Private Declare Function GetKeyboardState Lib "user32" _
() '   (kbArray As KeyboardBytes) As Long
Private Declare Function SetKeyboardState Lib "user32" _
Private Declare Function GetForegroundWindow Lib "user32" () As Long
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
  If CommandName = "TEXT" Or CommandName = "EATTEDIT" Or CommandName = "DTEXT" Or CommandName = "INSERT" Or CommandName = "DDATTE" Or _
  CommandName = "DDEDIT" Then
    GetKeyboardState kbArray
    kbArray.kbByte(VK_CAPITAL) = 1
    SetKeyboardState kbArray
  End If
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
    kbArray.kbByte(VK_CAPITAL) = 0
  End If
'End Code Block
I got this from CadVault , I think Randall Rath is the author
this goes inthe "This Drawing " module
« Reply #16 on: April 08, 2005, 10:57:53 AM »
I can't try your utility out because our security won't allow downloads but I'm sure it's pretty derned cool, so kudos to you Keith.
David Hall
« Reply #17 on: April 08, 2005, 11:02:26 AM »
Can you get it by email?  I'll send it to you w/o the EXE extension if that would help
« Reply #18 on: April 08, 2005, 11:05:14 AM »
That's a very kind offer CmdrDuh, but that will just set off a triple alarm (our scanner is not so easily fooled), so please don't.
:cheesy:
« Reply #19 on: April 08, 2005, 11:21:57 AM »
Updated -
Internet Explorer
FireFox
Netscape
Outlook
Outlook Express
AutoCAD products
Daron, I'll look into the possibility of having it interact with password boxes
daron
« Reply #20 on: April 08, 2005, 12:47:45 PM »
That'd be cool, thanks.
hudster
« Reply #21 on: April 08, 2005, 02:50:46 PM »
This is a sweet app Keith.
You are without doubt one of the finest individuals I know, in fact that goes for everyone on this site.  There isn't anyone here who is pretentious or too important to lend a bit of advice or support, and yes I'm even including Dent in that.  Even if he is a wee bit weird.
You are all amazing.
« Reply #22 on: April 08, 2005, 03:26:07 PM »
Good job, Keith....albeit just one glitch I've found in the new version. Since, I assume, you are using the Title in the application bar to determine what status to use there is a conflict when using Outlook Express to access the autodesk.autocad.anything newsgroups......it appears that the "autocad" overrides the "outlook".
Thanks again, this should save a lot of us some embarassment or at least a ton of retyping..... :D
« Reply #23 on: April 08, 2005, 03:47:30 PM »
Well, I'll see what I can do about that ... That is why we have beta testers ... (ya didn't know you were one of them buggers did you)
*edited*
Updated .... it "should" work properly now ... If not, I'll try again ... It was basically an error in the parsing ... all should be well..
hudster
« Reply #24 on: April 09, 2005, 07:43:48 AM »
Keith, When I click the about button, I get a runtime error 713 message and then the app crashes.
« Reply #25 on: April 09, 2005, 09:23:19 AM »
Check to see if you have these files on your system.
FM20.dll
comctl32.dll
stdole2.tlb
msvbvm60.dll
« Reply #26 on: April 09, 2005, 03:18:37 PM »
Key Keith, looks to me like you got it nailed now!
I like it!
Thanks again,
Jeff
Oh, and I couldn't duplicate Hudster's error......
hudster
« Reply #27 on: April 10, 2005, 06:32:56 AM »
I have them all except the fm20.dll file.
« Reply #28 on: April 10, 2005, 10:30:25 AM »
Ok, then that is your problem ... It can be downloaded from Microsoft from here
whdjr
« Reply #29 on: April 12, 2005, 10:46:53 AM »
Keith I know this was all done in jest but it works really well.  I have mine set to autoload at windows startup.  Do you think you might be able to add in a quiet startup so the dialog box does not come up every time windows starts?
please!please!please!please!please!please!
