Ok, I have tried to work this out, but I am getting no where. Let me tell you all what I am looking for.
On our plans, I try to turn off the extension lines on dimensions that fall on walls or other lines, just to keep the overlapping effect gone. To do this, I have been selecting each dimension line and changing its properties to turn off either the right, left or both extension lines. The variables for these are DIMSE1 & DIMSE2. The thing I want to do is create a button for each task. The problem I am having is that I cannot turn the DIMSE1 and DIMSE2 variables off all together because it would affect all of the dimensions. My thoughts are to have a button to allow me to select a certain dimension line, then allow me the option to turn off either the right, left or both extension lines without affecting the other ones that I did not select. Does anyone understand what I am trying to do here? Thanks
