Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
entity type in C#
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: entity type in C# (Read 1855 times)
Peter Guappa
Guest
entity type in C#
on:
March 16, 2014, 04:22:20 PM »
Hi all,
How can I get the entity type in C# (block - arc - line - ....) when hovering over an entity?
If it is a block, how can I get the block name?
Thx.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: entity type in C#
Reply #1 on:
March 16, 2014, 04:25:34 PM »
Have you read this ?
http://adndevblog.typepad.com/autocad/2014/02/detecting-entities-under-cursor-while-selection-is-running.html
Logged
fixo
Guest
Reply #2 on:
March 16, 2014, 04:27:24 PM »
This article may helps too
http://through-the-interface.typepad.com/through_the_interface/2009/07/providing-information-on-autocad-objects-in-a-tooltip-using-net.html
Logged
Mesozoic relic
Seagull
Reply #3 on:
March 16, 2014, 04:29:09 PM »
Thanks Oleg,
I came back to add that one
Logged
Peter Guappa
Guest
Reply #4 on:
March 16, 2014, 04:32:11 PM »
Thx guys!
Logged
Peter Guappa
Guest
Reply #5 on:
March 16, 2014, 05:12:24 PM »
I'm stuck. My C# knowledge is almost nil.
I can get the entity type by using "id.ObjectClass.Name"
But how can I get the block name?
if (id.ObjectClass.Name == "AcDbBlockReference")
Logged
Peter Guappa
Guest
Reply #6 on:
March 16, 2014, 05:43:05 PM »
got it
Logged
Andrey Bushman
Swamp Rat
Reply #7 on:
March 17, 2014, 12:17:21 AM »
Don't forget about the dynamic block instances.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
entity type in C#
