Author Topic: help!help!help!  (Read 4907 times)
Re: help!help!help!
« Reply #15 on: March 10, 2014, 10:14:00 PM »
If you ONLY select the lower 2 lines this will be the result
(((561.202 501.106 0.0) (644.977 501.106 0.0)) ((848.894 542.867 0.0) (904.572 542.867 0.0)))
(("A3" "A4") ("A11" "A12"))
Re: help!help!help!
« Reply #16 on: March 12, 2014, 01:51:43 AM »
Sometimes I wonder why I bother.
Re: help!help!help!
« Reply #17 on: March 12, 2014, 08:35:26 AM »
You should have replied No!No!No!  ;D
