Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
The selection set of entities combination?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: The selection set of entities combination? (Read 2458 times)
2e4lite
Guest
on:
March 07, 2014, 03:55:43 AM »
How to Select the entities ,which are the same type、layer、color、Perimeter and area if have in the specified range?
Logged
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: The selection set of entities combination?
Reply #1 on:
March 07, 2014, 05:42:42 AM »
The type/layer/color can very easily be selected using selection filters.
http://www.afralisp.net/autolisp/tutorials/selection-set-filters.php
The perimeter and area might be a different matter. You could do a selection first (using filters for the other properties), then step through it and remove those which do not fall within the rage(s). You can obtain the perimeter/area using various methods: just do a google on autolisp perimeter.
Edit: or even on this site:
http://www.theswamp.org/index.php?topic=22276.msg268230
http://www.theswamp.org/index.php?topic=39773.msg451108
Unfortunately you can't add custom selection filtering like you can in Revit - i.e. introduce a custom function which the select tool asks if the entity is acceptable before adding it to the selection set. That would have been great, but unfortunately not available in AutoCAD, definitely not in AutoLisp.
Logged
Global Moderator
Seagull
Reply #2 on:
March 07, 2014, 06:22:08 PM »
These are very old but may be of some use.
http://www.theswamp.org/index.php?topic=1915.0
Logged
2e4lite
Guest
Reply #3 on:
March 09, 2014, 03:26:29 AM »
CAB,
Thanks for your routine,It's good! In this line:(setq ent (car (entsel "\nSelect object to match area & layer."))). I think it will be more efficient in use,if use ssget to Select object In this line.
Logged
Global Moderator
Seagull
Reply #4 on:
March 09, 2014, 10:48:22 AM »
Feel free to modify for your needs.
Enjoy.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
