Author Topic: Check number side of polygon  (Read 4209 times)
miquan
« on: March 06, 2014, 11:07:12 AM »
Dear,
I have many grid line, I just want to triangle or rectangular shape (number of sides of each cell is smaller than or equal to 4 sides).
Are there any lisp to check that?
Thanks,
Miiquan
Re: Check number side of polygon
« Reply #1 on: March 06, 2014, 11:26:08 AM »
Not enough information for me.
I have never seen your drawing nor do I know what ACAD objects the grid lines are made of.
Perhaps you can explain it so your receptionist could understand the question & then I would too.  8)
« Reply #2 on: March 06, 2014, 12:35:28 PM »
If these polygons are drawn with the command 'polygon' this would give you the number of sides.
(vlax-curve-getEndParam (car (entsel)))
« Reply #3 on: March 06, 2014, 01:34:14 PM »
Or
(if (setq s (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))))
    (cdr (assoc 90 (entget (ssname s 0))))
« Reply #4 on: March 06, 2014, 05:06:08 PM »
Lee, I think that will fail if the polyline has Plinegen on. The dxf 70 is bit-coded .. so it's value could be 1 or 129 depending on Plinegen setting.
« Reply #5 on: March 06, 2014, 05:39:26 PM »
Hence the bitwise equals mask (-4 . &=)  :wink:
« Reply #6 on: March 06, 2014, 06:39:22 PM »
missed that ; I should look more closely, shouldn't I.
miquan
« Reply #7 on: March 07, 2014, 12:32:42 AM »
Dear CAB,
Sorry for not clear information.
I attached here with my grid lines, I broke them at their intersections.
I need a lisp to select all grids, after that check number of polygon cell.
If number of sides is larger than 4, these sides will be selected, and change layer (Ex: Grid_1).
Thanks,
Miquan
« Reply #8 on: March 08, 2014, 09:49:58 AM »
Hi Miquan,
You could use the programs shared in this thread to generate polylines for each grid cell, and then process the resulting polylines to check for those with more than 4 sides.
I hope this helps.
