Author Topic: Facing problem with Dynamic Block  (Read 3998 times)
HasanCAD
« on: March 06, 2014, 07:54:39 AM »
I am trying to automatizing the work.
One of this is creating a block for column; in some cases the column comes vertical or horizontal.
Problems which I am facing
- The parameter not shown in properties when select blocks with both visibility vertical and horizontal.
- Grips not shown in both visibility.
Thanx
Jeff H
Re: Facing problem with Dynamic Block
« Reply #1 on: March 06, 2014, 01:09:15 PM »
Open block in editor
Click BVMODE or the button circled red on left that will toggle invisible objects off or make visible with transparent screening
Change to Visibility state that grips etc.. do not appear.
Click BVShow button  and select grips.
Jeff H
« Reply #2 on: March 06, 2014, 01:13:38 PM »
Need to modify block though you will see how grips behave now they are visible in both states.
