Author Topic: Error: Automation Error. Problem in loading application  (Read 5803 times)
AngelKostadinov
« on: March 05, 2014, 03:50:57 AM »
Hello,
In our company we are using both .net and lisp extension functions for AutoCad 2010 - 2014 to help construction department. We have more than 50 PC with installed AutoCad and only few of them throw error when specific lisp command is executed -> Error: Automation Error. Problem in loading application.
You can find the lisp file with problematic function (RenameBlock) below.
I've searched internet for answer and found this -> http://www.cadforums.net/showthread.php/4309-vla-GetInterFaceObject-Automation-error, but didn't help a lot.
From CMD I run following command: regsvr32.exe axdb.dll but nothing happens because Register Service can't find proper entry point to register the DLL.
I will be very grateful to those of you who can explain why that error happens and how to solve the problem :)
Best regards,
Angel
NICK_VNV
Re: Error: Automation Error. Problem in loading application
« Reply #1 on: March 05, 2014, 04:23:01 AM »
This topic helped me with the same problem  http://www.theswamp.org/index.php?topic=40871.msg461180#msg461180
Sorry for my English...
AngelKostadinov
« Reply #2 on: March 05, 2014, 06:59:51 AM »
On my development  machine in registry there is following record HKEY_CLASSES_ROOT\ObjectDBX.AxDbDocument.18\CLSID, but on the machine that's throwing the error, there isn't.
Please check the attached picture from my dev machine.
I can create this registry folder hierarchy through Registry Editor, but how to create the last record with name: (Default) and Data: {EBF0F8FD-632A-4AB8-8D71-E77217898747}.
I copied just this simple method for registering dll into registry. When I am calling ASDDSA inside AutoCad on my dev machine the number 33 is returned.
The lisp function has to make the same thing that I am trying to accomplish manually with Registry Editor, isn't it?
(defun C:ASDDSA()
(startapp "regsvr32.exe" (strcat "/s \" C:\axdb.dll\""))
« Reply #3 on: March 05, 2014, 03:54:50 PM »
Firstly, the latest version of that program may be found here.
Regarding the error you are receiving, you can attempt to register the DLL required for ObjectDBX using the following program:
;; Register ObjectDBX (Verbose version)  -  Lee Mac
;; Attempts to register the AxDb.dll as required by ObjectDBX.
;; Returns T if successful or if the dll is already registered, else returns nil.
(defun c:regodbx ( / cmd dll key vrs )
    (print
        (or
                (vl-registry-read
                    (setq key
                        (strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument"
                            (if (= 15 (setq vrs (atoi (getvar 'acadver))))
                                "\\CLSID"
                                (strcat "." (itoa vrs) "\\CLSID")
                (princ (strcat "\nObjectDBX already registered at\n" key))
                (or
                        (setq dll (findfile (strcat "AxDb" (itoa vrs) ".dll")))
                        (princ (strcat "\nFound file: " dll))
                        (setq dll (findfile "AxDb.dll"))
                    (not
                        (princ (strcat "\nNeither AxDb" (itoa vrs) ".dll nor AxDb.dll could be found."))
                (or
                    (startapp "regsvr32.exe" (setq cmd (strcat "\"" dll "\" /s")))
                    (startapp (strcat (getenv "WinDir") "\\System32\\regsvr32.exe") cmd)
                    (startapp (strcat (getenv "WinDir")   "\\System\\regsvr32.exe") cmd)
                    (not (princ (strcat "\nUnable to register dll: " dll)))
                (vl-registry-read key)
    (textpage) (princ)
(vl-load-com) (princ)
I hope this helps!  :-)
AngelKostadinov
« Reply #4 on: March 07, 2014, 02:18:09 AM »
Excellent! Thank you very much!
« Reply #5 on: March 08, 2014, 09:51:05 AM »
You're welcome!
Can I assume that the program solved the issue?
