Author Topic: Add Reactor to Popup Alert Lisp Routine  (Read 2880 times)
ROBBO
« on: March 04, 2014, 05:58:14 AM »
What am I doing wrong? I am trying to add a reactor to activate Lee Mac's Popup subfunction with the qsave and save commands to alert user once a day when commands are activated, but unable to get it to work.
Any ideas would be much appreciated. Please see code below:
;;-------------------------=={ Popup }==----------------------;;
;;  Displays a pop-up message box prompting the user.         ;;
;;  Author: Lee Mac, Copyright © 2012 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  title - Text to be displayed in the pop-up title bar      ;;
;;  msg   - Text content of the pop-up message box            ;;
;;  flags - Integer indicating icon & button appearance       ;;
;;          Reference: http://lee-mac.com/popup.html          ;;
;;  Returns:  Integer indicating the button pressed to exit   ;;
;;Reactor added by Robbo 2014-03-04
(defun LM:Popup (callling-reactor
commandwillstart_list)
(alert
(car commandwillstart_list ))
(if (member (car commandwillstart_list)'("QSAVE" "SAVE"))
(defun LM:Popup ( title msg flags / wsh res )
    (if (setq wsh (vlax-create-object "wscript.shell"))
            (setq res (vl-catch-all-apply 'vlax-invoke-method (list wsh 'popup msg
0 title flags)))
            (vlax-release-object wsh)
            (if (null (vl-catch-all-error-p res))
                res
(defun IWillOnlyRunOnceADay nil
;;Popup text added by Robbo 2014-03-04
(LM:Popup ".bak file Information" "Please Note. To avoid project directory
clutter, .bak files are saved in your C:\\Temp_Acad\\Backup directory\n \nYou
may notice the benign error '_qsave Unable to transmit selected drawing
file.'\nThis is just a notification stating the .bak file wasn't saved in the
'expected' location - nothing to worry about!" (+ 0 64 4096))
(not
(and
(setq date (getenv "LMAC_OnceADay"))
(= (fix (getvar 'DATE)) (atoi date))
(IWillOnlyRunOnceADay)
(setenv "LMAC_OnceADay" (itoa (fix (getvar 'DATE))))
Many thanks in advance, Robbo.
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Re: Add Reactor to Popup Alert Lisp Routine
« Reply #1 on: March 04, 2014, 08:24:35 AM »
Try something like this .You have to define the command reactor before you can call it.
;; COMMAND REACTOR
(or *commandreactors*
    (setq *commandreactors* (vlr-command-reactor nil '((:vlr-commandwillstart . strtcmd))))
(defun strtcmd (calling-reactor strtcmdinfo / date)
  (if (wcmatch (car strtcmdinfo) "*SAVE*")
      (defun lm:popup (title msg flags / wsh res)
    (setq res (vl-catch-all-apply 'vlax-invoke-method (list wsh 'popup msg 0 title flags)))
      res
      (if (not (and (setq date (getenv "LMAC_OnceADay")) (= (fix (getvar 'date)) (atoi date))))
  (lm:popup
    (strcat
      "Please Note. To avoid project directory clutter, .bak files are saved in your C:\\Temp_Acad\\Backup directory"
      "\nYou may notice the benign error '_qsave Unable to transmit selected drawing file."
      "\nThis is just a notification stating the .bak file wasn't saved in the 'expected' location - nothing to worry about!"
    (+ 0 64 4096)
  (setenv "LMAC_OnceADay" (itoa (fix (getvar 'date))))
ROBBO
« Reply #2 on: March 04, 2014, 08:54:26 AM »
Thank you ronjonp. Worked a treat!
As you can tell I am new to lisp, but never too old to learn!  :wink:
Cheers, Robbo
Oscar Wilde
« Reply #3 on: March 04, 2014, 08:59:09 AM »
Glad to help  :)
