Author Topic: Hatch pattern to look like Hidden linetype or what's wrong with this .pat file?  (Read 4431 times)
alanjt
  • Standby for witty remark...
So, I gave up on the idea of continuing to use the centerline of my pipe (civil 3d pipe networks), set with a width of the inner wall of my pipe, since it won't properly trim at the structure, even though it trims the out/inside walls accordingly. I've now been trying to create a hatch that will mimic the Hidden linetype, but I've never created a custom hatch pattern and it's proving to be a bit over my head.
« Last Edit: February 27, 2014, 09:42:11 PM by alanjt »
Dropbox
What is this hatch supposed to look like?
Are you hatching a long rectangle / pipe?
Are you working in English units & feet?
The error is that the name in the file exactly.
The file says storm & the definition says stormpipe.
Consider this:
*test
0, 0, 0, 0, .01, 2, -2
alanjt
Looks like just a line drawn with the "Hidden" linetype, set to a width of the pipe's inner wall.
Yes, long, rectangular pipe.
Imperial.
Holy crap, that worked. Thank you so much, Alan.
Consider this:
*test
When I brought that in, I could select it, but said there was an error on line 2 when it tried to create a hatch object with that pattern.
Dropbox
Worked for me.
Stupid question, did you name the file test.pat?  8)
Did you add a carriage return on the last line?
alanjt
Worked for me.
Yes.
That was it.
OK, I got yours working and it's a lot better. It actually aligns to the pipe properly. Thank you so much. This is perfect.
Dropbox
Glad it worked out.
alanjt
Glad it worked out.
Thank you again. :)
On to my many other items that need crossing off my list. :lol:
Dropbox
Jeff H
Cab you need to set up paypal account because my company owes 1,000s of dollars of time saved when told them to quit erasing polylines in arch plans used to get area of rooms and to use them as a boundary for your 2x2 and 2x4 ceiling grid hatch to create ceiling grids.
Thanks Jeff,
That's one of those benefits of hanging out at the Swamp.  8)
alanjt
Thanks Jeff,
And I can't thank you enough for bring me here so many years ago. :)
Dropbox
TimSpangler
  • CAD Naked!!
Thanks Jeff,
Now we know who to blame for leaving to door open........Thanks CAB  :laugh: j/k
ACA 2015 - Windows 7 Pro
alanjt
Thanks Jeff,
:lol: We Alans have to stick together.
Dropbox
Scary who comes through to door sometimes but we make converts of them all.  :)
alanjt
lol. Very true. There are other sites, but nothing quite adds up to the talent here.
Dropbox
