Author Topic: [C3D 2013] Note label with reference text (referencing point) losing link  (Read 2649 times)
alanjt
  • Standby for witty remark...
When you change a note label style that uses a reference to a point to a different style, or even a child style, that also includes that same reference, the link is broken, and the only way to fix it is to step through each label individually and reselect from the properties palette. Has anyone come across a better solution for this?
Dropbox
Re: [C3D 2013] Note label with reference text (referencing point) losing link
« Reply #1 on: February 20, 2014, 02:18:44 PM »
Yep, don't change the style. :-(
alanjt
« Reply #2 on: February 20, 2014, 02:36:24 PM »
Arg. I was hoping that wasn't going to be the response. ATM, I'm only displaying the elevation, but I need to display a description from a few and was hoping I could just create a secondary style and quickly change. I should have known better.
Thanks, Jeff.
Dropbox
