EDIT: At the moment I pressed "Post" I got the idea ... Solution see below.
I have an arc, given with startpoint, endpoint, radius and centre. Should be easy, but at the moment I have no idea how to calculate the MID of the arc (I'm confused about direction of rotation, angles > 2pi
Any hints?
Thanks.
EDIT: Solution:
(polar zen (angle zen (mapcar '(lambda (x) (* 0.5 x))(mapcar '+ start end))) rad)
which means ..
- calculate the middle of START and END (helppoint)
- calculate the point with Polar from centre with direction to helppoint and with length of radius
Should do it ...
Peter
