Author Topic: Obfuscation for C#.net  (Read 6787 times)
nobody
  • .net stuff
« on: February 17, 2014, 11:32:47 PM »
Can anyone recommend software to do this?  Still need the junk to work in autocad and civil 3d.
exmachina
Re: Obfuscation for C#.net
« Reply #1 on: February 17, 2014, 11:59:45 PM »
« Reply #2 on: February 18, 2014, 12:02:13 AM »
We use Dotfuscator for the SincpacC3D, but it is $$. I've used a free one for my personal projects that seems to do a nice job and is very easy to use....Eazfuscator.NET, the link for this is jar's link.
exmachina
« Reply #3 on: February 18, 2014, 12:08:41 AM »
...a free one for my personal projects that seems to do a nice job and is very easy to use....Eazfuscator.NET...
Eazfuscator is no longer free   :-(
nobody
  • .net stuff
« Reply #4 on: February 18, 2014, 12:12:49 AM »
Thanks all you rock (course you knew that already) :)
« Reply #5 on: February 18, 2014, 12:15:07 AM »
Bummer! Looks like you can still find the last free version, which will work as long as you don't need .NET 4.5: LINK
exmachina
« Reply #6 on: February 18, 2014, 12:50:42 AM »
We use Dotfuscator for the SincpacC3D, but it is $$....
I am sorry, but the assemblies obfuscated with Dotfuscator can be easily deofuscated. It is obvious that not everyone knows how to do this, but maybe Dotfuscator is not the best option.
with ildasm.exe (http://msdn.microsoft.com/es-es/library/f7dy01k1%28v=vs.110%29.aspx):
Keith Brown
« Reply #7 on: February 18, 2014, 04:53:33 PM »
Its not free but I have used RedGate's SmartAssembly with success.
CADbloke
  • Crash Test Dummy
« Reply #8 on: February 18, 2014, 05:28:34 PM »
This: https://bitbucket.org/0xd4d/de4dot/ is the most easily-accessible de-obfuscator around so you may want to run your obfuscated code through it to see what it spits out. There are others around too like http://netdeob0.codeplex.com/ etc. Google is your friend (or not).
Everything can be cracked, you just want ot make it hard for the casual crackers. See also http://stackoverflow.com/questions/2525/net-obfuscation-tools-strategy and related questions.
Personally, I'd want to be running a lot of unit tests against obfuscated code, just to be a little more sure it doesn't break.
huiz
  • Certified Prof C3D
« Reply #9 on: February 19, 2014, 03:31:42 AM »
Indeed. Once I found out that overloaded functions with the same number of parameters can be a problem for some obfuscator software. So you need to test everything. Even when you can't imagine the obvious functions would fail.
nobody
  • .net stuff
« Reply #10 on: August 27, 2017, 06:03:45 PM »
Using this now...really like it
http://www.rustemsoft.com/obfuscator.asp
