I tried that route, and it displays well enough, but when you set a width to the pline, the dot is now a thin line. I tried having the linetype begin with nothing, but you have to at least being with a dot.
Here's what I had:
*PIPE-CENTER,Pipe Center . __ __ __ __ __ __ __ __ __ __ __ __ __ .
A,0,.25,-.125
I think I'm going to have to go back to trying to make a hatch pattern that will look as close to the hidden linetype as possible. I can almost accomplish what I want with ANSI34, but I'd like to see if I can get it a little closer to the Hidden linetype. This being said, is it possible to create a hatch pattern with a pattern where its' a space and then several lines together to appear as one thick line?
Thank you, Alan.
