Author Topic: SAC Fixed elavation  (Read 3424 times)
lamarn
SAC Fixed elavation
« on: January 31, 2014, 11:33:54 AM »
I want  to build a subassambly witk a fixed elevation of a wall. Does anyone have a clue what the expression is to be used? I thing something that in the order of this below...
thanks in regard
http://wikihelp.autodesk.com/AutoCAD_Civil_3D/enu/2013/Help/Autodesk_Subassembly_Composer/0081-Entering81/0086-API_Func86/0091-Elevatio91
lamarn
Re: SAC Fixed elavation
« Reply #1 on: February 07, 2014, 04:28:42 AM »
sollution in SAC
input output list: create a parameter (Side)H1 (Type)Double (Direction)Input (Value)-2,00 (Name)height requered. Create Point Py.
Make a Link Py_Px, Type: Delta x Delta Y and assign in Delta Y following formula (H1-Px.Elevation), with x the number of the  point.
http://www.c3dbenelux.eu/media/kunena/attachments/26/wandelement.jpg
