Author Topic: MNL loaded twice.  (Read 2923 times)
Andrea
MNL loaded twice.
« on: January 31, 2014, 09:56:56 AM »
Hi guys,...
maybe I'm wrong or there is something weird on my settings...
but I've noted that all MNL files are loaded twice.
I put this code in acad.mnl and some custom.mnl files.
(if (not ordre) (setq ordre 0))
(alert (strcat "your filename.your extension    " (itoa (setq ordre (1+ ordre)))))
the order of Loading files when open AutoCAD is:
1 - ACAD.mnl
2 - all custum mnl files...
5 - ACAD.lsp
6 - ACADDOC.lsp
7 - all custum mnl files...
11 - all other custom vlx and lsp files...
can any one confirm that ?
Keep smile...
dgorsman
Re: MNL loaded twice.
« Reply #1 on: January 31, 2014, 10:51:25 AM »
What happens if you switch workspaces?  Another MNL load?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Andrea
« Reply #2 on: January 31, 2014, 10:57:55 AM »
I don't think the Workspace interfer to the file loading order..
but I'll test...
Keep smile...
Andrea
« Reply #3 on: January 31, 2014, 11:00:20 AM »
well,..
no diffrence,..any workspace,...any profile....
also,....basic installation do same think without any custom settings.
Keep smile...
snownut2
  • Bricscad 22 Ultimate
« Reply #4 on: January 31, 2014, 02:45:43 PM »
I have noticed this issue with Briscad, but never in Acad.  I always unload a menu file before loading it, just to prevent this type of issue.
In Briscad when loaded multiple times it shows up on menu-bar for each instance.
Bruce
dgorsman
« Reply #5 on: January 31, 2014, 04:04:44 PM »
well,..
The question wasn't related to an issue with the workspace, but rather to see if changing between workspaces causes a reload.  If that's true, then what could be happening at start-up is the first load is AutoCAD starting with the last available workspace, then it sets the workspace active as part of document start-up.
try {GreatPower;}
   finally
      {MasterBasics;}
Marc'Antonio Alessi
  • Marco
« Reply #6 on: February 02, 2014, 05:04:16 AM »
this happens only  when you start autocad or every time you open a dwg ?
Andrea
« Reply #7 on: February 02, 2014, 10:03:12 AM »
yes,..mnl files are loaded each time a new drawing is created or opened..  :wink:
However,...after many tests,..this issue is present only with AutoCAD Network license....
So now it seem to be an AutoCAD issue for me...Otherwise,....don't know how that's happen.. :pissed:
Is some of you may confirm that, I'll report that to Autodesk,...just knowing their feedback.
thank you guys,.
Keep smile...
Marc'Antonio Alessi
  • Marco
« Reply #8 on: February 02, 2014, 12:22:25 PM »
I do not have AutoCAD with Network license, this only happens with some versions of AutoCAD and only at startup, this is 2013 Mechanical version (Vanilla profile):
Il file di personalizzazione è stato caricato senza problemi. Gruppo di personalizzazione: ACAD
Il file di personalizzazione è stato caricato senza problemi. Gruppo di personalizzazione: ALIAS_CONCEPT
Rigenerazione layout in corso.
_cuiunload
Digitare nome di un gruppo di personalizzazione da scaricare:ALIAS_CONCEPT
File di personalizzazione scaricato senza problemi. Gruppo di personalizzazione: ALIAS_CONCEPT
_cuiload c:\program files\autodesk\applicationplugins\sbd.bundle\contents\aalsbin\it-IT\AliasConcept.cuix
_wscurrent
Caricamento delle utilità dei menu di AutoCAD avvenuto.
Crank
« Reply #9 on: February 02, 2014, 12:42:12 PM »
I'm seeing the same thing. It's not only the .mnl, but almost all .cuix-files are loaded twice. It looks like this has something to do with .bundles (see attachement).
I've tried to unload the .cuix-files of the .bundles, but the next time they are added inmediately again  (even if the CUIX isn't stored in the profile :realmad: )
Right now this isn't a big issue, since this PC is only used for development. On our network the problem doesn't occur. :)
Andrea
« Reply #10 on: February 02, 2014, 01:19:40 PM »
thank you Guys,..
Not a Big Issue,..but just sharing information about it..
because some client tool use acad.lsp and/or acaddoc.lsp and then set some variable in there...
so when the mnl is loaded,..these variable are reset twice.
 :whistle:
Keep smile...
