// divide2.cs
// © Andrey Bushman, 2014
using System;
using System.Linq;
using System.Text;
using System.IO;
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Gem = Autodesk.AutoCAD.Geometry;
using Rtm = Autodesk.AutoCAD.Runtime;
[assembly
: Rtm
.CommandClass(typeof(Bushman
.CAD.Commands.Divide))]
namespace Bushman.CAD.Commands {
public class Divide : Rtm.IExtensionApplication {
const String ns = "Bushman";
static Int32 div_count = 2;
const String msg0 = "The selection set has not the Line objects.\n";
const String msg = "The command is interrupted.\n";
/// <summary>
/// To convert the each Line object in the Pline3d object and
/// to divide them on some count of segments.
/// </summary>
[Rtm.CommandMethod(ns, "divide2", Rtm.CommandFlags.UsePickSet | Rtm.CommandFlags.Redraw
| Rtm.CommandFlags.Modal | Rtm.CommandFlags.NoPaperSpace)]
public void Divide2() {
App.Document doc = cad.DocumentManager.MdiActiveDocument;
Ed.Editor ed = doc.Editor;
Db.Database db = doc.Database;
Ed.PromptSelectionResult psr;
psr = ed.SelectImplied();
Db.ObjectId[] ids = null;
if (psr.Status == Ed.PromptStatus.OK) {
ids = psr.Value.GetObjectIds().Where(id => id.ObjectClass.Name == "AcDbLine")
.ToArray();
if (ids != null && ids.Length > 0) ed.SetImpliedSelection(ids);
else {
ed.WriteMessage(msg0);
ed.WriteMessage(msg);
return;
else {
Db
.TypedValue[] typeValues
= new Db
.TypedValue[1]; typeValues
.SetValue(new Db
.TypedValue((Int32
)Db
.DxfCode.Start,
"LINE"),
0); Ed
.SelectionFilter filter
= new Ed
.SelectionFilter(typeValues
); psr = ed.GetSelection(filter);
if (psr.Status != Ed.PromptStatus.OK) {
return;
if (ids == null) ids = psr.Value.GetObjectIds();
Ed
.PromptIntegerOptions pio
= new Ed
.PromptIntegerOptions("Segments count"); pio.AllowNegative = false;
pio.AllowNone = false;
pio.AllowZero = false;
pio.DefaultValue = div_count;
Ed.PromptIntegerResult result = ed.GetInteger(pio);
if (result.Status != Ed.PromptStatus.OK) {
return;
else {
div_count = result.Value;
using (Db.OpenCloseTransaction tr = db.TransactionManager.StartOpenCloseTransaction()) {
foreach (Db.ObjectId id in ids) {
Db.Line line = (Db.Line)tr.GetObject(id, Db.OpenMode.ForWrite);
Gem
.Point3dCollection points
= new Gem
.Point3dCollection(); Gem.Point3d point = line.StartPoint;
points.Add(line.StartPoint);
Double dx = line.Delta.X / div_count;
Double dy = line.Delta.Y / div_count;
Double dz = line.Delta.Z / div_count;
for (int i = 1; i < div_count; i++) {
point
= new Gem
.Point3d(point
.X + dx, point
.Y + dy, point
.Z + dz
); points.Add(point);
points.Add(line.EndPoint);
Db
.Polyline3d pline
= new Db
.Polyline3d(Db
.Poly3dType.SimplePoly, points,
false);
pline.SetDatabaseDefaults();
pline.LayerId = line.LayerId;
pline.Color = line.Color;
pline.ColorIndex = line.ColorIndex;
pline.LinetypeId = line.LinetypeId;
pline.LinetypeScale = line.LinetypeScale;
pline.LineWeight = line.LineWeight;
line.HandOverTo(pline, true, true);
tr.Commit();
ed.WriteMessage("Transformed objects count: {0}.\n", ids.Length);
#region IExtensionApplication Members
public void Initialize() {
ed.WriteMessage("\n{0}. © Andrey Bushman, 2014\n\n",
Path.GetFileName(this.GetType().Assembly.Location));
public void Terminate() {
#endregion
