Author Topic: transfer point coordinates from Block to Space  (Read 1312 times)
Coder
« on: January 29, 2014, 12:31:21 AM »
Hello guys .
I thought to get coordinates of a point in my Block is simple but I found out the coordinates of the point object is faraway from the correct location of the block , strange to me ! :-o
Is there a way to transfer the coordinates of that point object to current active space in my autocad ?
Many thanks in advance .  :-)
reltro
Re: transfer point coordinates from Block to Space
« Reply #1 on: January 29, 2014, 11:37:07 AM »
Hey Coder...
I had the same Problem short time ago...
I solved it so I wanna share
(defun BCS2WCS (BlockRef pointlist / ent inspkt ang)
    (setq ent (entget BlockRef))
    (setq inspkt (cdr (assoc 10 ent)))
    (setq ang (cdr (assoc 50 ent)))
    (mapcar
        '(lambda (Pt /)
            (trans
                (mapcar
                    (polar
                        '(0 0 0)
                        (+ ang (angle '(0 0 0) Pt))
                        (distance '(0 0 0) Pt)
                    inspkt
                BlockRef
                0
        pointlist
(defun WCS2BCS (BlockRef pointlist / ent inspkt ang)
    (mapcar
        '(lambda (Pt /)
            (apply
                '(lambda (x y z / )
                    (list
                        (+ (* x (cos ang)) (* y (sin ang)))
                        (- (* x (sin ang)) (* y (cos ang)))
                        z
                (mapcar
                    (trans
                        Pt
                        0
                        BlockRef
                        'T
                    InsPkt
        pointlist
I named the function with BCS... BlockCoordinateSystem ;)
maybe, if u need it, u have to add a multiplication with the scale...
Hope it helps
greets
reltro
Coder
« Reply #2 on: January 30, 2014, 12:08:59 AM »
Hi reltro .
Thank you so much for sharing your nice work , it works great .  :-)
You are awesome .
