Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Geometry Problem
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Geometry Problem (Read 2531 times)
Dave M
Newt
Geometry Problem
on:
January 19, 2014, 10:57:28 PM »
Okay, I am being really dense. I need to rotate the circle and its tangent line about the center of the large arc, (which also happens to be the end of the line) so that the small circle will be tangent to the line above it. Can someone help me see what I am not seeing? Thanks!
Logged
Civil 3D 2018 - Microstation SS4 - Windows 10 -
Dropbox
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Geometry Problem
Reply #1 on:
January 20, 2014, 01:02:55 AM »
OFFSET THE TOP LINE BY THE RADIUS OF THE SMALLER CIRCLE
DRAW A CIRCLE P1 -> P2
ROTATE THE SMALLER CIRCLE FROM P1 RELATIVE TO P1-> P2 TO P1-> P3
IE THE CENTER OF THE SMALL CIRCLE WILL TRANSLATE FROM P2 TO P3
Last Edit: January 20, 2014, 01:08:26 AM by Kerry
Logged
Dave M
Newt
Reply #2 on:
January 20, 2014, 02:56:42 AM »
Thank you Kerry! As soon as I saw your image I knew what I was doing wrong. I knew I needed to draw another circle, but I wasn't sure where. I love The Swamp!
Thanks again
Dave
Logged
Dropbox
Mesozoic relic
Seagull
Reply #3 on:
January 20, 2014, 07:40:41 AM »
You're welcome Dave.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Geometry Problem
