Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Could someone make one layer not to add any entity
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Could someone make one layer not to add any entity (Read 2744 times)
connieleo
Guest
on:
April 01, 2005, 02:32:38 AM »
I want make a especial layer which can not add any entity. Is it possible?
Thanks in advance.
Logged
Seagull
Have thousands of dwgs to process? Contact me.
WWW
Reply #1 on:
April 01, 2005, 06:35:13 AM »
You could probably achieve what you ask by some reactor slight of hand but can I ask what purpose such a layer serves?
Logged
cadanalyst@gmail.com
http://cadanalyst.slack.com
http://linkedin.com/in/cadanalyst
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
April 01, 2005, 07:47:59 AM »
A layer with its locked property set to True comes to mind ...
.. but as MP noted, It would require some black magic to ensure it stayed locked in all circumstances.
Logged
Seagull
WWW
Reply #3 on:
April 01, 2005, 07:49:52 AM »
Ahhh, but you can add entities to locked layers, you just can't modify / delete 'em once they're on said layer.
Logged
Mesozoic relic
Seagull
Reply #4 on:
April 01, 2005, 07:55:49 AM »
duh !!
.. I'm having visions of an old crone stirring a cauldron ..
bubble, bubble, toil and trouble .....
Logged
Seagull
WWW
Reply #5 on:
April 01, 2005, 07:57:49 AM »
Hey, where'd you find my pic!?
Logged
CADaver
Guest
Reply #6 on:
April 01, 2005, 08:28:58 AM »
ummm... what for?? Do you mean a layer that can have NO entities or a layer that you can't add any new entities??
I'm soooo cunfused.
Logged
Mesozoic relic
Seagull
Reply #7 on:
April 01, 2005, 08:38:20 AM »
I'm guessing here,
connieleo may want to ONLY be able to add/remove entities/objects programmatically using HIS routines.
.. I can see some use for that ..
Logged
CADaver
Guest
Reply #8 on:
April 01, 2005, 09:15:00 AM »
Ahhhhh.... okay, I can see that.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
