Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
the fill pattern scale
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: the fill pattern scale (Read 2852 times)
2e4lite
Guest
on:
January 08, 2014, 09:42:05 PM »
How to dynamically change the fill pattern scale?
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: the fill pattern scale
Reply #1 on:
January 08, 2014, 11:45:07 PM »
From the help file
Code - Auto/Visual Lisp:
[Select]
;; Find the scale of the hatch pattern
setq
patternScale
vla-get-PatternScale
hatchObj
alert
strcat
"The scale of the hatch pattern is "
rtos
patternScale
2
;; Change the scale of the hatch pattern
vla-put-PatternScale
hatchObj
patternScale
2
vla-Evaluate
hatchObj
vla-Regen
doc
:vlax-true
If you mean interactively dynamic ( using grread or some such) I don't have a sample handy.
You could also modify the DXF code representing hatch scale (dxf 41 I think would work)
Last Edit: January 08, 2014, 11:53:28 PM by Kerry
Logged
Global Moderator
Seagull
Reply #2 on:
January 09, 2014, 08:58:15 AM »
Here is one and there are others I think:
http://www.theswamp.org/index.php?topic=26444.30
Another
http://www.theswamp.org/index.php?topic=26448.msg319545#msg319545
Last Edit: January 09, 2014, 09:37:13 PM by CAB
Logged
2e4lite
Guest
Reply #3 on:
January 09, 2014, 08:37:51 PM »
Thank you both for enthusiastic reply!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
