I am looking for a lisp routine to label doors in AutoCAD 2010. I had one at my old job that basically zoomed in on each door, measured the width of that particular door opening, generated the label and gave your he opportunity to place the label where you wanted. If it matters, I use a layer called "P-doors" for the doors and "FP-text" is the layer that the label will be on. Any help would be greatly appreciated.
Thanks!!
