Author Topic: entmod not modifying  (Read 2227 times)
daron
« on: March 30, 2005, 12:22:34 PM »
I'm trying to throw together a little function that will take the xvalue of a list of selected objects, get the greatest xvalue of all objects and substitute that value into the xvalue of said objects. Here's what I have so far.
ename list should be a list of ename objects
(defun lineupText (enamelist / xval puttoval newlist)
     (setq xval    (mapcar '(lambda (x) (car (cdr (assoc 11 (entget x)))))
   enamelist
  puttoval (car (vl-sort xval '>))
  (setq newlist (subst puttoval
(entget x)
  (entmod newlist)
  (entupd x)
    objs
I'm sure this could be made cleaner, but this is just the first go around. Will someone please tell me why entmod isn't updating the list?
Thank you.
« Reply #1 on: March 30, 2005, 12:39:39 PM »
Perhaps --
(defun LineUpText ( enames / x pair data )
    ;; get minimum x coordinate for all entities 11 group
    (setq x
        (apply 'min
            (mapcar
               '(lambda (ename) (cadr (assoc 11 (entget ename))))
                enames
    ;;  apply minx to all entities
    (foreach ename enames
        (entmod
            (subst
                (cons 11
                    (cons x
                        (cddr
                            (setq pair
                                (assoc 11
                                    (setq data (entget ename))
                pair
                data
        (entupd ename)
daron
« Reply #2 on: March 30, 2005, 01:05:29 PM »
Okay, I see what I was doing wrong. I was adding just the value and needed to add the list. Doh! Nice code.
« Reply #3 on: March 30, 2005, 01:07:38 PM »
Glad it helped, and thanks for the compliment.
