Author Topic: Acad 2009  (Read 3179 times)
PHX cadie
Acad 2009
« on: December 17, 2013, 01:41:28 PM »
Since the ribbon question was solved, (Thxs!!), thought I'd start a thread with a collection of questions that wil slowly pop up with time. Sorry if they've been covered before.
In 05 I'd select a dim, rt clk and a lot of options would pop up ( precision/ move text etc.) In 09 rt clk it's copy.
How do get the dim pop up back?
How do I the single open back? (Dont see in 09 options)
Thxs for the time/patience
Acad 2013 and XM
Rob...
Re: Acad 2009
« Reply #1 on: December 17, 2013, 04:23:49 PM »
You're posts will get more visibility if you make a new topic for new questions. Plus, it will keep the answers on topic. Obvously, questions related to answers given here should be posted here.
« Last Edit: December 17, 2013, 04:28:44 PM by RobDraw »
CAD Tech
Rob...
Re: Acad 2009
« Reply #2 on: December 17, 2013, 04:27:35 PM »
Right click options, I think, are in User Preferences or Drafting.
CAD Tech
JNieman
Re: Acad 2009
« Reply #3 on: December 17, 2013, 04:42:11 PM »
Bingo.  What's likely happening to you is that it's repeating the last command or something.  You'll probably want to enable right-click-menus when an object is selected.  May as well take a closer look at the other contexts for right-click-functions while you're there, and make sure they jive with you.
PHX cadie
Re: Acad 2009
« Reply #4 on: December 18, 2013, 09:34:27 AM »
Right click options, I think, are in User Preferences ............
 :-) Thxs
Acad 2013 and XM
