hi,rough tool to update specific attributes with field from another object.after FIE i got #### instead correct attributes value.weird thing is that after edit #### and press ok value is fine.thankskruuger
Quote from: kruuger on December 12, 2013, 04:54:21 AMhi,rough tool to update specific attributes with field from another object.after FIE i got #### instead correct attributes value.weird thing is that after edit #### and press ok value is fine.thankskruugerChange line: Code - Auto/Visual Lisp: [Select](setq id (LM:ObjectID (vlax-ename->vla-object en))to:Code - Auto/Visual Lisp: [Select](setq id (LM:ObjectID (vlax-ename->vla-object %))because en is an insert object, and % is an attributtekojacek
