/* © Andrey Bushman, 2013
* AutoCAD 2014 x64 SP1
* The sample, how to save the some settings of your custom controls into the AWS file.
* I showed the feature of the "IConfigurationSection.Save" event's registration if the palette has not the child controls.
using System;
using Microsoft.Win32;
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Rtm = Autodesk.AutoCAD.Runtime;
using Win = Autodesk.AutoCAD.Windows;
[assembly
: Rtm
.CommandClass(typeof(Bushman
.CAD.Problems.Commands))]
namespace Bushman.CAD.Problems {
public class Commands {
[Rtm.CommandMethod("cmd_4", Rtm.CommandFlags.Modal)]
public void Command_4() {
Ed.Editor ed = cad.DocumentManager.MdiActiveDocument.Editor;
// This settings will be saved into the
// %AppData%\Autodesk\AutoCAD 2014\R19.1\enu\Support\Profiles\Unnamed Profile\Profile.aws
// if the current profile is the <<Unnamed Profile>>.
Win
.PaletteSet palette_set
= new Win
.PaletteSet("My Palette",
new Guid
("{49DBC66F-21BE-4D9F-A5A9-BA750543042E}")); palette_set
.Load += new Win
.PalettePersistEventHandler(palette_set_Load
); palette_set
.Save += new Win
.PalettePersistEventHandler(palette_set_Save
// WARNING! If you will comment the next code line, the 'Save' event not occurs!
// I think it is a bug of API.
palette_set
.Saving += new Win
.PalettePersistEventHandler(palette_set_Saving
palette_set.KeepFocus = true;
palette_set.Visible = true;
void palette_set_Save(object sender, Win.PalettePersistEventArgs e) {
palette_set_Save(e.ConfigurationSection);
void palette_set_Saving(object sender, Win.PalettePersistEventArgs e) {
// The empty implementation...
// This names can't to contain the spaces (it will used as the xml
// element's and attribute's names)!
const String name = "AAA";
const String name2 = "BBB";
const String val_1_name = "Value_1";
const String val_2_name = "Value_2";
void palette_set_Load(object sender, Win.PalettePersistEventArgs e) {
App.IConfigurationSection section = e.ConfigurationSection;
App.IConfigurationSection subsection = null;
App.IConfigurationSection subsection2 = null;
if (!section.IsReadOnly) {
Boolean n = section.ContainsSubsection(name);
if (n)
subsection = section.OpenSubsection(name);
else
subsection = section.CreateSubsection(name);
if (!subsection.IsReadOnly) {
Boolean b = subsection.ContainsSubsection(name2);
if (b)
subsection2 = subsection.OpenSubsection(name2);
else
subsection2 = subsection.CreateSubsection(name2);
Int32 val_1 = (Int32)subsection2.ReadProperty(val_1_name, 100);
Int32 val_2 = (Int32)subsection2.ReadProperty(val_2_name, 200);
void palette_set_Save(App.IConfigurationSection section) {
if (section == null || section.IsReadOnly)
return;
Boolean b = section.ContainsSubsection(name);
if (b)
else
if (subsection != null && !subsection.IsReadOnly) {
Boolean n = subsection.ContainsSubsection(name2);
if (n)
else
if (subsection2 != null && !subsection2.IsReadOnly) {
subsection2.WriteProperty(val_1_name, 123);
subsection2.WriteProperty(val_2_name, 456);
