Author Topic: Bearing Orientation and distanse to *.txt  (Read 7727 times)
Re: Bearing Orientation and distanse to *.txt
« Reply #15 on: December 08, 2013, 05:15:24 PM »
Have a play with something like this perhaps :
  1. (defun c:bearing2txt (/ *error* fname  vp vps ep eps p3 s3 fn incl_ang)
  2.   (defun *error* (msg)
  3.     (if (= 'file (type fn))
  4.       (close fn)
  5.     )
  6.     (if (null (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  7.       (princ (strcat "\nError: " msg))
  8.     )
  9.     (princ)
  10.   )
  11.   ;;------------------------------
  12.   (setq fname (getfiled "Save Text File As:" "" "txt" 1))
  13.   (setq vp  (getpoint "\nPick Base Vertex point: ")
  14.         vps (getstring "\nEnter Label Base Reference point: ")
  15.         ep  (getpoint vp "\nPick Base Second point: ")
  16.         eps (getstring "\nEnter Label of Second point: ")
  17.   )
  18.   (while (and (setq p3 (getpoint vp (strcat "\nPick Bearing point :")))
  19.               (setq s3 (getstring "\nEnter Label of point: "))
  20.          )
  21.     (if (> (car vp) (car ep))
  22.       (cal "incl_ANG=ANG(VP,P3,EP)")
  23.       (cal "incl_ANG=ANG(VP,EP,P3)")
  24.     )
  25.     (setq fn (open fname "a"))
  26.     (write-line (strcat vps ": " (vl-princ-to-string vp)) fn)
  27.     (write-line (strcat eps ": " (vl-princ-to-string ep)) fn)
  28.     (write-line (strcat s3 ": " (vl-princ-to-string p3)) fn)
  29.     (write-line (strcat "Distance " vps "->" s3 ": " (rtos (distance vp p3) 2 2)) fn)
  30.     (write-line (strcat "Angle "    eps "->" vps "->" s3 ": " (rtos incl_ang 2 6)) fn)
  31.     (write-line " ***" fn)
  32.     (close fn)
  33.   )
  34.   (*error* nil)
  35.   (princ)
  36.
  37. )
  38.
  39.
vp: (2876.41 2749.1 0.0)
ep: (998.326 2749.1 0.0)
p1: (4098.56 4418.83 0.0)
Distance vp->p1: 2069.22
Angle ep->vp->p1: 126.202130
p2: (1919.34 4327.0 0.0)
Distance vp->p2: 1845.47
Angle ep->vp->p2: 58.761219
p3: (5303.42 3782.05 0.0)
Distance vp->p3: 2637.68
Angle ep->vp->p3: 156.945096
p4: (3746.29 1714.6 0.0)
Distance vp->p4: 1351.62
Angle ep->vp->p4: 229.940411
p5: (1351.58 1647.18 0.0)
Distance vp->p5: 1881.31
Angle ep->vp->p5: 324.146384
« Last Edit: December 08, 2013, 05:19:45 PM by Kerry »
pedroantonio
« Reply #16 on: December 08, 2013, 06:03:24 PM »
Thank you for the try but the code still have the same error. Can not exort txt file
I want to export a file like this
1,116.827,12.46
2,138.869,13.55
3,159.3097,14.05
4,182.1792,13.11
and the root stop after the third point !! I want to use it for more like the photo in first post !!
« Reply #17 on: December 08, 2013, 06:48:58 PM »
I'm sure you can modify the code to suit your particular requirements.
I'm not going to do any more on this. It works perfectly for me as you can see from the result data I posted.
If you expect me to write the code for you ;  I'm afraid you don't understand what the swamp is about.
Contact me privately if you want commercial quality code written rather than concept code ... but be prepared to pay commercial rates for the work.
pedroantonio
« Reply #18 on: December 26, 2013, 06:56:52 PM »
I write this code but I need some help !!
  1. (defun c:bear2txt (/ p1 p11 p2 p21 p3 p31 d1 fname)
  2.   (setq p1 (getpoint "\nPick Base Referene point: "))
  3.   (setq p11 (getstring "\nEnter Label Base Referene point: "))
  4.   (setq p2 (getpoint p1 "\nPick Second point: "))
  5.   (setq p21 (getstring "\nEnter Label of Second point: "))
  6.
  7.   (progn
  8.     (setq angs (If (> (car p1) (car p2))
  9.                  "ang(p1,p3,p2)"
  10.                  "ang(p1,p2,p3)"
  11.                )
  12.     )
  13.     (while (setq p3 (getpoint p1 (strcat "\nPick point :")))
  14.       (setq p3l (getstring "\nEnter Label of point: "))
  15.       (setq d1 (rtos (distance p1 p3) 2 2))
  16.       data
  17.     )
  18.   )
  19.
  20.   (princ)
  21.   (setvar "cmdecho" 0)
  22.      (str fname (getfiled "Save Text File As:" "" "txt" 1) fil)
  23.
  24.      (close fil)
  25.      (format stream content)
  26.    )
  27.     (princ)
  28.   )
  29. )
  30.
I want to export a txt file like this
point number,angle,distance
« Reply #19 on: December 26, 2013, 09:57:47 PM »
Play with this:
  6.
  7.   (setq angs (if (> (car p1) (car p2))
  8.                "ang(p1,p3,p2)"
  9.                "ang(p1,p2,p3)"
  10.              )
  11.   )
  12.   (setq data (list p21 p2 p11 p1))
  13.
  14.   (while (setq p3 (getpoint p1 (strcat "\nPick point :")))
  15.     (setq data (cons p3 data))
  16.     (setq p31 (getstring "\nEnter Label of point: "))
  17.     (setq data (cons p31 data))
  18.     (setq d1 (rtos (distance p1 p3) 2 2))
  19.     (setq data (cons d1 data))
  20.   )
  21.
  22.   (princ)
  23.   (setvar "cmdecho" 0)
  24.   (setq fname (getfiled "Save Text File As:" "" "txt" 1))
  25.   (setq fil (open fname "w"))
  26.   (mapcar '(lambda (x) (write-line (vl-princ-to-string x) fil)) (reverse data))
  27.   (close fil)
  28.   (princ)
  29. )
« Reply #20 on: December 26, 2013, 10:11:42 PM »
Pedro,
I'm reminded of this
http://www.theswamp.org/index.php?topic=45804.msg509623#msg509623
perhaps you could show the exact format you want the file to have.
« Reply #21 on: December 27, 2013, 12:30:00 AM »
I merged the two threads.
pedroantonio
« Reply #22 on: December 28, 2013, 04:27:29 AM »
thank you CAB but this lisp gives me coordinate and distance, i need  angle and distance. How i can do it ?
« Reply #23 on: December 28, 2013, 06:14:03 AM »
< .. > this lisp gives me coordinate and distance, i need  angle and distance. How i can do it ?
What have you tried that doesn't work as you want. ?
mailmaverick
« Reply #24 on: December 28, 2013, 07:47:02 AM »
Try This
  (setq fname (getfiled "Save Text File As:" (getvar 'dwgprefix) "TXT" 1))
  (If (< (car p1) (car p2))
    (progn (setq tmp p1) (setq p1 p2) (setq p2 tmp))
  (setq cnt 1)
  (setq pn p1)
  (while (not (equal pn nil))
    (if (setq pn (getpoint (strcat "\nPick point " (itoa cnt) " : ")))
      (progn (setq pnl (getstring (strcat "\nEnter Label of point " (itoa cnt) " : ")))
     (write-line
       (strcat pnl "," (rtos (distance p1 pn) 2 2) "," (rtos (- (angle p1 p2) (angle p1 pn)) 2 2))
       fil
     (setq cnt (1+ cnt))
  (alert (strcat (itoa (- cnt 1)) " points written in file " fname))
  (close fil)
snownut2
  • Bricscad 22 Ultimate
« Reply #25 on: December 28, 2013, 08:46:59 AM »
Almost sounds like you guys are doing someone's homework !
pedroantonio
« Reply #26 on: December 28, 2013, 11:12:32 AM »
Thank you mailmaverick but the angle is not correct
  6.   (setq fname (getfiled "Save Text File As:" (getvar 'dwgprefix) "TXT" 1))
  7.   (setq fil (open fname "w"))
  8.   (If (< (car p1) (car p2))
  9.     (progn (setq tmp p1) (setq p1 p2) (setq p2 tmp))
  10.   )
  11.   (setq cnt 1)
  12.   (setq pn p1)
  13.   (while (not (equal pn nil))
  14.     (if (setq pn (getpoint (strcat "\nPick point " (itoa cnt) " : ")))
  15.       (progn (setq pnl (getstring (strcat "\nEnter Label of point " (itoa cnt) " : ")))
  16.              (write-line
  17.                (strcat pnl "," (rtos (- (angle p1 p2) (angle p1 pn)) 2 2) "," (rtos (distance p1 pn) 2 2))
  18.                fil
  19.              )
  20.              (setq cnt (1+ cnt))
  21.       )
  22.     )
  23.   )
  24.   (alert (strcat (itoa (- cnt 1)) " points written in file " fname))
  25.   (close fil)
  26.   (princ)
  27. )
  28.
This is the correct angles
1,116.827,12.46
2,138.869,13.55
3,159.3097,14.05
4,182.1792,13.11
The angle must be (p2 , p1 , pn ) in grads
The distasne (p1,pn) is correct
The *.dwg file will help you ..
« Last Edit: December 28, 2013, 11:27:02 AM by pedroantonio »
roy_043
  • BricsCAD 18
« Reply #27 on: December 29, 2013, 10:30:14 AM »
Instead of the (rtos) function, (angtos) should be used for the angle.
pedroantonio
« Reply #28 on: December 29, 2013, 11:52:49 AM »
Now is working
  10.   )
  11.   (setq cnt 1)
  12.   (setq pn p1)
  16.              (write-line
  17.                (strcat pnl "," (angtos (+ (angle p2 p1) (angle p1 pn) ) 2 4) "," (rtos (distance p1 pn) 2 2))
  18.                fil
  19.              )
  21.       )
  22.     )
  23.   )
  25.   (close fil)
  26.   (princ)
  27. )
  28.
  29.
but i have an error with the angle
calculate this angles
1,16.8274g,12.46
2,38.8698g,13.55
3,59.3097g,14.05
4,82.1792g,13.11
and the correct are  this
1,116.8274g,12.46
2,138.8698g,13.55
3,159.3097g,14.05
4,182.1792g,13.11
« Reply #29 on: December 29, 2013, 12:42:21 PM »
Another offering.
  1. (defun c:bear2txt (/ p1 p1L p2 p2L pn lbl data cnt fil fname)
  2.     ;; Get Inside Angle  -  Lee Mac
  3.     ;; Returns the smaller angle subtended by three points with vertex at p2
  4.     (defun LM:GetInsideAngle ( p1 p2 p3 )
  5.        (   (lambda ( a ) (min a (- (+ pi pi) a)))
  6.            (rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))
  7.        )
  8.     )
  9.
  10.
  11.   (setq p1 (getpoint "\nPick Base Referene point: "))
  12.   (setq p1L (getstring "\nEnter Label Base Referene point: "))
  13.   (setq p2 (getpoint p1 "\nPick Second point: "))
  14.   (setq p2L (getstring "\nEnter Label of Second point: "))
  15.  (If (< (car p1) (car p2))
  16.    (setq tmp p1
  17.          p1 p2
  18.          p2 tmp
  19.          tmp p1L
  20.          P1L p2L
  21.          p2L tmp)
  22.  )
  23.
  24.   (setq data (list (strcat "Base point " (vl-princ-to-string p1) "Label " p1L)))
  25.   (setq data (cons (strcat "Second point " (vl-princ-to-string p1) "Label " p2L) data))
  26.   (setq data (cons "Cnt, Angle, Dist., Label" data))
  27.
  28.   (setq cnt 1)
  29.   (while (setq pn (getpoint p1 (strcat "\nPick point :")))
  30.     (setq lbl (getstring "\nEnter Label of point: "))
  31.     (setq data (cons
  32.                  (strcat (itoa cnt) ","
  33.                          (angtos (LM:GetInsideAngle p2 p1 pn) 2 4) ","
  34.                          (rtos (distance p1 pn) 2 2) " "
  35.                          lbl)
  36.                  data))
  37.     (setq cnt (1+ cnt))
  38.   )
  39.
  40.   (setq fname (getfiled "Save Text File As:" "" "txt" 1))
  41.   (setq fil (open fname "w"))
  42.   (mapcar '(lambda (x) (write-line x fil)) (reverse data))
  43.   (close fil)
  44.   (princ)
  45. )
