Author Topic: Bearing Orientation and distanse to *.txt  (Read 7547 times)
mailmaverick
Re: Bearing Orientation and distanse to *.txt
« Reply #30 on: December 29, 2013, 12:45:50 PM »
Dear Pedro
Corrected code is as follows :-
(defun c:bear2txt (/ p1 p11 p2 p21 p3 p31 d1 fname)
  (setq p1 (getpoint "\nPick Base Referene point: "))
  (setq p11 (getstring "\nEnter Label Base Referene point: "))
  (setq p2 (getpoint p1 "\nPick Second point: "))
  (setq p21 (getstring "\nEnter Label of Second point: "))
  (setq
    fname (getfiled "Save Text File As:" (getvar 'dwgprefix) "TXT" 1)
  (setq fil (open fname "w"))
  (If (< (car p1) (car p2))
    (progn (setq tmp p1) (setq p1 p2) (setq p2 tmp))
  (setq cnt 1)
  (setq pn p1)
  (while (not (equal pn nil))
    (if (setq pn (getpoint (strcat "\nPick point " (itoa cnt) " : ")))
      (progn (setq
       pnl (getstring
     (strcat "\nEnter Label of point " (itoa cnt) " : ")
     (setq ang (/ (* (- (angle p1 p2) (angle p1 pn)) 200) pi))
     (write-line
       (strcat (itoa cnt)
       pnl
       (rtos ang 2 2)
       (rtos (distance p1 pn) 2 2)
       fil
     (setq cnt (1+ cnt))
  (alert
    (strcat (itoa (- cnt 1)) " points written in file " fname)
  (close fil)
pedroantonio
« Reply #31 on: December 30, 2013, 02:46:11 AM »
Thank you mailmaverick your lisp work perfect
Don't forget  to thank CAB,Kerry ,Lee Mac,dgorsman,snownut2,roy_043 for there  advises.
Thank you all , Marry Christmas and Happy new year !!!!!!!!!!!!
pedroantonio
« Reply #32 on: December 30, 2013, 03:59:05 AM »
Sorry again mailmaverick i find a little problem with Exterior Angle. Gives me negative angles. Can you fix this ? Here is my *dwg file to understand the problem ..
thanks
mailmaverick
« Reply #33 on: December 30, 2013, 05:38:06 AM »
Dear Pedro
Problem of Negatives corrected !!!!!
  (setq
  (setq cnt 1)
  (setq pn p1)
      (progn (setq
       pnl (getstring
     (if (< ang 0)
       (setq ang (+ ang 400))
     (write-line
       (strcat (itoa cnt)
       pnl
       (rtos ang 2 2)
       "g,"
       fil
     (setq cnt (1+ cnt))
  (alert
  (close fil)
roy_043
  • BricsCAD 18
« Reply #34 on: December 30, 2013, 05:52:18 AM »
but i have an error with the angle
The (angtos) function takes the ANGBASE variable into account. This may explain the wrong values.
« Last Edit: December 30, 2013, 06:05:51 AM by roy_043 »
pedroantonio
« Reply #35 on: December 30, 2013, 06:00:34 AM »
Thank you mailmaverick now works perfect
Happy new year to all ............
