Author Topic: write block names to file  (Read 5433 times)
David Hall
  • Automatic Duh Generator
« on: December 03, 2013, 01:54:09 PM »
I cant seem to get my block names to write out to a file.  I have my File Scripting Object working, but I am having trouble iterating through my block collection.
David Hall
Re: write block names to file
« Reply #1 on: December 03, 2013, 01:56:58 PM »
This is basically what I am doing
objSelset.Select acSelectionSetAll
Dim objblkname As AcadBlockReference
For Each objblkname In objSelset
MyFile.Writeline objblkname.Name
Next
I crashed autocad and I hadn't saved, so I put that together from memory
David Hall
« Reply #2 on: December 03, 2013, 01:58:13 PM »
Part of the problem is some of the things in the selectionset aren't blocks, so there is no NAME property, so that is where it crashes.  I can't seem to get it to only return inserted blocks
« Reply #3 on: December 03, 2013, 08:53:25 PM »
Hi David,
Seems like you need a property.available test.
MickD
« Reply #4 on: December 04, 2013, 01:13:09 AM »
either that or set up your selection set with a filter ;)
<edit> found a quick link with some info: http://adndevblog.typepad.com/autocad/2012/07/vba-how-to-setup-selectionset-filters-for-a-block-or-layer.html
« Last Edit: December 04, 2013, 01:17:06 AM by MickD »
J.R.R. Tolkien
« Reply #5 on: December 04, 2013, 01:32:57 AM »
Yep,
Will any of these blocks be dynamic?
If so, you may need to deal with EffectiveName for BlockReferences.
David Hall
« Reply #6 on: December 04, 2013, 11:29:03 AM »
Thanks guys, that was what I needed.  All is good
