Author Topic: Multiple block visibulity states  (Read 3799 times)
jumpy
« on: November 29, 2013, 07:30:14 AM »
Hi all, I've had a bit of a search online and have not found any information on altering the visibility state of multiple instances of the same block. Is this possible?
Eg. I have an electrical outlet with the following visibility states:
switched twin socket
unswitched twin socket
switched spur
unswitched spur
commando socket
If I have 10 instances of this dynamic block, and I select them and globally update their visibility states from, say, switched twin socket, to unswitched spur.
I was hoping for something with some similarity to the FIND command in its functionality (maybe too much to ask hehe).
I'm using LT here so there's no lisp.
I don't know if lookup tables would help or if LT can use them... plus they're unknown to me with dynamic blocks at this time.
Acad 2018 / LT2018
TimSpangler
  • CAD Naked!!
Re: Multiple block visibulity states
« Reply #1 on: November 29, 2013, 01:58:45 PM »
Select the blocks, go to properties, there should be a property called "Visibility" change it to the desired state.
Done!
ACA 2015 - Windows 7 Pro
jumpy
« Reply #2 on: December 02, 2013, 04:28:03 AM »
Ha, thanks. Sometimes it should be so obvious what to do  :oops:  :lol:
Acad 2018 / LT2018
