Thanks for your Reply Irneb.
I have searched the whole registry but I could not find the GUID for the application.
Here is what I did.
1, Run a batch file... ABCD.exe /regserver
2, Trying to make an object as shown in their example code.
Private Sub Form_Load()
Set Kc = New KeyCheck ' Create object of KeyCheck ActiveX
Kc.KeyID = *** ' Define Key ID
etc.
Reply from Support Contact.
The KeyCheck ActiveX is available in
xxx\KeyCheck ActiveX\xxx\ABCD.exe
You have to register it first by using the provided Register.bat.
I do not understand VB code but with the comments I can understand a bit.
Some Questions
1, Is set function make a variable kc?
2, Is Kc.KeyID also a variable?
3, Is it correct to make an ActiveX Object of ABCD.exe.?
Thanks and Best Regards
