Author Topic: Save txt-file on internet, read file from internet  (Read 3677 times)
cadplayer
« on: November 18, 2013, 03:11:53 AM »
Hello!
Have anybody a tip how I can create a txt-file for reading on Internet, something like this http://www.opendcl.com/version/version.txt. I want save som strings, that all people in my company can read.
Woabow
Re: Save txt-file on internet, read file from internet
« Reply #1 on: November 18, 2013, 04:29:00 AM »
Try this, based on this post:
http://www.theswamp.org/index.php?topic=45220.msg504240#msg504240
;; Retrieves a text file from http://www.opendcl.com
;; Based on Password Generator  -  Lee Mac
;; http://www.theswamp.org/index.php?topic=45220.msg504240#msg504240
(defun readwwwtxt ( / obj rtn )
        (if (setq obj (vlax-get-or-create-object "winhttp.winhttprequest.5.1"))
                (setq rtn
                    (vl-catch-all-apply
                        (function
                            (lambda ( )
                                (vlax-invoke-method obj 'open "GET"
                                    (strcat
                                        "http://www.opendcl.com/version/version.txt"
                                    :vlax-false
                                (vlax-invoke-method obj 'send)
                                (vlax-get-property  obj 'responsebody)
                (vlax-release-object obj)
                (if (vl-catch-all-error-p rtn)
                    (princ (vl-catch-all-error-message rtn))
                    (princ
                        (vl-list->string
                            (mapcar '(lambda ( x ) (lsh (lsh x 24) -24))
                                (vlax-safearray->list (vlax-variant-value rtn))
(vl-load-com) (princ)
cadplayer
« Reply #2 on: November 18, 2013, 05:00:13 AM »
Thanks that works perfect with "opendcl-txt-file" but if I want read my dropbox-file (readwwwtxt "https://www.dropbox.com/s/sac7a555twkxle0/131016-1S.txt")
it comes the hole html-code
<!DOCTYPE html><html lang="en" xmlns:fb="http://ogp.me/ns/fb#" xml:lang="en" class="" xmlns="http://www.w3.org/1999/xhtml"><head>
            <script type="text/javascript">
                window._document_observe_listeners = [];
                document.observe = function(event, func) {
                    window._document_observe_listeners.push({event: event, func: func});
                window._jquery_ready_handlers = [];
                jQuery = function(handler) {
                    window._jquery_ready_handlers.push(handler);
                function on_script_loaded(func) {
                    (window.LoadedJsSuccessfully && document.loaded) ? func() : document.observe('script:loaded', func);
            </script>
Woabow
« Reply #3 on: November 18, 2013, 05:44:44 AM »
The Dropbox page does not only show the text, but a complete page with HTML formating.
Put the text file in your Public folder and put the "public link" in the lisp, example:
"https://dl.dropboxusercontent.com/u/2190289/3dcircle.txt"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: November 18, 2013, 05:47:34 AM »
Hello!
why not use the Autodesk 360 store?
cadplayer
« Reply #5 on: November 18, 2013, 06:36:59 AM »
I have test it, but I canīt read directly my file. I must first download it.
The test with this url works
_$ (readwwwtxt "http://www.opendcl.com/version/version.txt")
6.0.2.5
_$
I want do my own txt.file and save them on www but there I donīt find a option there I can save my file only for reading. Always I have to download first.
for in this file you find coordinates https://www.dropbox.com/s/sac7a555twkxle0/131016-1S.txt
(readwwwtxt "https://www.dropbox.com/s/sac7a555twkxle0/131016-1S.txt") should give me
1001,6399639.0050,140917.0395,14.1900,35
1002,6399639.0427,140917.0612,14.1883,33
1003,6399637.9412,140920.9416,14.2981,33
1004,6399637.7453,140922.4169,14.2106,30
1005,6399636.4977,140925.1814,12.9932,37
1006,6399643.8283,140920.0239,14.2999,21
1007,6399644.9423,140922.3941,14.2907,23
1008,6399646.0801,140924.0623,14.2830,28
1009,6399647.4268,140925.8188,14.0676,62
1010,6399658.3731,140934.0247,12.8735,37
1011,6399660.2911,140929.7799,14.2301,30
1012,6399660.8362,140928.7482,14.4935,33
1013,6399661.8820,140925.2360,14.4253,33
1014,6399662.7536,140923.3580,14.1661,34
1015,6399663.7824,140920.9240,14.3407,33
1016,6399665.5760,140925.0868,14.4027,42
1017,6399676.4439,140925.0100,14.4442,33
1018,6399676.0636,140926.9903,14.3849,34
1019,6399675.7558,140929.1346,14.5302,33
1020,6399674.6807,140933.1402,14.6979,33
1021,6399674.5812,140934.4774,14.6329,30
1022,6399674.1669,140938.0629,13.5475,37
1023,6399687.9067,140942.0012,13.6892,37
1024,6399688.9051,140939.0079,14.6122,30
1025,6399689.2605,140937.4530,14.7784,33
1026,6399690.2661,140933.7134,14.6481,33
1027,6399690.8919,140931.8043,14.3896,34
1028,6399691.5671,140929.1749,14.5694,33
1029,6399705.3710,140932.8291,14.6457,33
1030,6399705.1060,140934.7105,14.2285,34
1031,6399704.4094,140937.3823,14.7591,33
1032,6399703.5584,140941.2014,14.9165,33
1033,6399703.4167,140942.4247,14.6681,30
1034,6399703.0543,140945.3158,13.7486,37
1035,6399701.5285,140933.8234,14.2286,24
1036,6399704.4092,140934.7291,14.2568,62
1037,6399708.8118,140934.3335,14.6512,62
1038,6399709.7948,140937.8926,15.1640,63
1039,6399709.7559,140937.8959,15.1487,63
1040,6399719.4849,140936.3540,14.8049,33
1041,6399719.3641,140938.1597,14.4041,34
1042,6399719.0379,140940.6971,14.9729,33
1043,6399718.4117,140944.4596,15.0808,33
1044,6399718.4342,140944.4669,15.0816,33
1045,6399717.9532,140947.8248,13.7029,37
1046,6399732.2193,140950.4480,14.0333,37
1047,6399732.9822,140947.4080,15.2299,33
1048,6399733.0431,140947.3724,15.2237,33
1049,6399733.5920,140943.5537,15.0932,33
1050,6399733.9187,140941.3102,14.6559,34
1051,6399734.2865,140939.1526,14.9514,33
1052,6399749.0539,140941.4067,15.0798,33
1053,6399748.8937,140943.2010,14.7193,34
1054,6399748.5960,140945.9247,15.1997,33
1055,6399748.1738,140949.7447,15.3530,33
1056,6399747.5850,140952.4295,14.3471,37
1057,6399761.6958,140954.3137,14.5520,37
1058,6399762.0116,140951.8847,15.4454,
but it comes message like before
« Last Edit: November 18, 2013, 06:57:29 AM by cadplayer »
« Reply #6 on: November 18, 2013, 06:59:45 AM »
Woabow
« Reply #7 on: November 18, 2013, 07:07:00 AM »
(readwwwtxt "https://dl.dropboxusercontent.com/u/2190289/131016-1S.txt")
cadplayer
« Reply #8 on: November 18, 2013, 07:48:42 AM »
Wow it works
How did you get the link dl.dropboxusercontent.com I did not find a publish button on dropbox?
Woabow
« Reply #9 on: November 18, 2013, 07:54:02 AM »
Public folder, not publish:
https://www.dropbox.com/help/16/en
Oh, wait, they have removed this...?
cadplayer
« Reply #10 on: November 18, 2013, 07:56:36 AM »
Ahhh
I get it, I hade not have a public Folder. That was reason why I did not working https://dl.dropboxusercontent.com/...
cadplayer
« Reply #11 on: November 18, 2013, 07:57:09 AM »
Thanks all!
