Author Topic: Range Function  (Read 10237 times)
ribarm
  • Marko Ribar, architect
Re: Range Function
« Reply #30 on: November 18, 2013, 10:09:40 AM »
  1. (defun range (s e i f)
  2.   (if (or (and (> i 0) (< s e)) (and (< i 0) (> s e)))
  3.     (progn (f s) (range (+ i s) e i f))
  4.   )
  5. )
  6.
  7. (defun test (s e i / tot)
  8.   (setq tot 0)
  9.   (range s e i (lambda (a) (setq tot (+ tot a))))
  10.   tot
  11. )
  12.
  13. (test 0 10 1) >> 45
  14. (test 0 10 1) >> 45
  15.
« Last Edit: November 18, 2013, 10:29:22 AM by ribarm »
M.R. on Youtube
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #31 on: November 18, 2013, 10:14:29 AM »
  1. (defun test (s e i a / tot)
  2.   (range s e i (lambda (a) (setq tot (+ tot a))))
  3.   tot
  4. )
  5.
  6. (test 0 10 1 0) >> 45
  7. (test 0 10 1 0) >> 45
  8.
 :-D
  1. (test 0 10 1 0) ; >> 45
  2. (test 0 10 1 55) ; >> 100
ribarm
Re: Range Function
« Reply #32 on: November 18, 2013, 10:37:29 AM »
So what, little testings where I was wrong...
  4.   )
  5. )
  6.
  7. (defun test (s e i tot)
  8.   (range s e i (lambda (a) (setq tot (+ tot a))))
  9.   tot
  10. )
  11.
  12. (test 0 10 1 0) >> 45
  13. (test 0 10 1 0) >> 45
  14. (test 0 10 1 55) >> 100
  15.
« Last Edit: November 18, 2013, 11:18:22 AM by ribarm »
M.R. on Youtube
ElpanovEvgeniy
  • Moscow (Russia)
Re: Range Function
« Reply #33 on: November 18, 2013, 10:41:43 AM »
it was my bug...
ymg
Re: Range Function
« Reply #34 on: November 18, 2013, 11:47:08 AM »
  1. ;;  By Cab      (iterative)                                                   ;
  2. ;;        ;
  3.
  4. (defun in_rangec (start end step / value)
  5.   (setq value (list start))
  6.   (repeat (fix (/ (- end start) step))
  7.      (setq value (cons (setq start (+ step start)) value))
  8.   )
  9.   (reverse (if (= (car value) end) (cdr value) value))
  10. )
  11. ;; By ElpanovEvgeniy       (recursive)                                        ;
  12. (defun in_range (s e i)
  13.   (if (or (and (> i 0) (< s e)) (and (< i 0) (> s e)))
  14.     (cons s (in_range (+ i s) e i))
  15.   )
  16. )
  17.
  18.
  19. (defun c:test ()
  20.   (setq ti (car (_vl-times)))
  21.   (repeat 5000
  22.      (setq tot 0)
  23.      (foreach i (in_range 0 10 1)
  24.         (setq tot (+ tot i))
  25.      )
  26.   )
  27.   (princ (strcat "\nRecursive in_range(): " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
  28.   (princ)
  29. )
  30.
  31. (defun c:test1 ()
  32.   (setq ti (car (_vl-times)))
  33.   (repeat 5000
  34.      (setq tot 0)
  35.      (foreach i (in_rangec 0 10 1)
  36.         (setq tot (+ tot i))
  37.      )
  38.   )
  39.   (princ (strcat "\nIterative in_range(): " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
  40.   (princ)
  41. )
  42.
  43. (defun c:test2 ()
  44.   (setq ti (car (_vl-times)))
  45.   (repeat 5000
  46.      (setq tot 0 i 0)
  47.      (repeat 9
  48.         (setq tot (+ tot (setq i (1+ i))))
  49.      )
  50.   )
  51.   (princ (strcat "\nTraditionnal Index: " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
  52.   (princ)
  53. )
  54.
_$ (c:test)
Recursive in_range(): 0.109 secs
_$ (c:test1)
Iterative inrange(): 0.109 secs
_$ (c:test2)
Traditionnal Index: 0.047 secs
_$
ribarm
Re: Range Function
« Reply #35 on: November 18, 2013, 01:02:15 PM »
It should be almost like (c:test2)...
  1. (defun c:test3 ()
  3.  (setq n (- (length (in_range 0 10 1)) 1)) ;;; or (setq n (- (length (in_rangec 0 10 1)) 1))
  4.  (repeat 5000
  5.     (setq tot 0 i 0)
  6.     (repeat n
  7.        (setq tot (+ tot (setq i (1+ i))))
  8.     )
  9.  )
  10.  (princ (strcat "\nTraditionnal combined Index: " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
  11.  (princ)
  12. )
  13.
  14. (defun c:test4 ()
  15.  (setq ti (car (_vl-times)))
  16.  (setq l (in_range 0 10 1)) ;; or (setq l (in_rangec 0 10 1))
  17.  (repeat 5000
  18.     (setq tot 0)
  19.     (foreach i l
  20.        (setq tot (+ tot i))
  21.     )
  22.  )
  23.  (princ (strcat "\nForeach in_range(): " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
  24.  (princ)
  25. )
  26.
« Last Edit: November 18, 2013, 01:24:19 PM by ribarm »
M.R. on Youtube
ymg
Re: Range Function
« Reply #36 on: November 18, 2013, 09:53:16 PM »
Marko,
You are right test4 is more like the real situation and comes out at
exactly the same time as the traditional index.
_$ (c:test4)
Foreach in_range(): 0.047 secs
roy_043
  • BricsCAD 18
Re: Range Function
« Reply #37 on: November 19, 2013, 03:49:58 AM »
@ ymg & ribarm
Benchmarking is not a 'real situation'. If you are trying to benchmark the range functions you should keep it inside the (repeat 5000 ...) loop.
roy_043
  • BricsCAD 18
Re: Range Function
« Reply #38 on: November 19, 2013, 04:15:19 AM »
Benchmarking .......... elapsed milliseconds / relative timing <5000 iterations>
  (KGA_LIST_INDEXSEQMAKESTARTEND 0 100) ..... 125 / 4.62 <fastest>
  (CAB_IN_RANGE 0 100 1) .................... 235 / 2.46
  (EE_IN_RANGE 0 100 1) ..................... 578 / 1.00 <slowest>
My function (KGA_List_IndexSeqMakeStartEnd) is not a true range function, but I think the numbers confirm the effectiveness of the speed improvement method for large ranges (0-100).
For the (CAB_in_range) and (EE_in_range) functions see reply #34 by ymg.
ymg
Re: Range Function
« Reply #39 on: November 19, 2013, 04:56:42 AM »
@ ymg & ribarm
roy_043,
What we are trying to assess is How it compares to a traditionnal incrementing of a separate index
in a loop.
That means that Marko's logic is right for the case at hand.
In other word using this method or the traditional one is essentially equivalent time-wise.
And yes we could use your code and maybe gain a little.
ymg
To be complete:
;; By roy_043        ;
(defun in_ranger (start end / len ret step)
  (setq step (if (< start end) -1 1))
  (repeat (rem (setq len (fix (abs (- end start)))) 8)
    (setq ret (cons (setq end (+ end step)) ret))
  (repeat (/ len 8)
    (setq ret
      (vl-list*
        (+ end (* 8 step))
        (+ end (* 7 step))
        (+ end (* 6 step))
        (+ end (* 5 step))
        (+ end (* 4 step))
        (+ end (* 3 step))
        (+ end (* 2 step))
        (+ end step)
        ret
    (setq end (+ end (* 8 step)))
  ret
(defun c:testr ()
 (setq l (in_ranger 0 10)) ;; or (setq l (in_rangec 0 10 1))
 (repeat 5000
    (setq tot 0)
    (foreach i l
 (princ (strcat "\nForeach in_ranger(): " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs"))
(c:testr)
Foreach in_ranger(): 0.0470 secs
« Last Edit: November 19, 2013, 05:39:17 AM by ymg »
Re: Range Function
« Reply #40 on: November 19, 2013, 07:20:11 AM »
@roy: Just curious, why 8? Why not more (or less)?
roy_043
  • BricsCAD 18
Re: Range Function
« Reply #41 on: November 19, 2013, 08:50:58 AM »
From my test file:
;;; 20111115
;;; Conclusions:
;;; The (repeat) loop with (setq) is very time consuming.
;;; Using serial (cons) is usually slower than using (vl-list*).
;;; Using (append) is of course bad for speed.
;;; (KGA_LIST_INDEXSEQMAKELENGTH_08) has an acceptable balance between speed gain and program length.
; Benchmarking .......... elapsed milliseconds / relative timing <1000 iterations>
  ; (KGA_LIST_INDEXSEQMAKELENGTH_32 1000) ...... 125 / 2.88 <fastest>
  ; (KGA_LIST_INDEXSEQMAKELENGTH_16 1000) ...... 140 / 2.57
  ; (KGA_LIST_INDEXSEQMAKELENGTH_08 1000) ...... 172 / 2.09
  ; (KGA_LIST_INDEXSEQMAKELENGTH_04 1000) ...... 234 / 1.54
  ; (KGA_LIST_INDEXSEQMAKELENGTH_01 1000) ...... 360 / 1.00 <slowest>
Re: Range Function
« Reply #42 on: November 19, 2013, 09:55:53 AM »
Very thorough roy  :-)
roy_043
  • BricsCAD 18
Re: Range Function
« Reply #43 on: November 20, 2013, 06:48:51 AM »
