Author Topic: Entmakex Block Attributes  (Read 2567 times)
AARYAN
« on: November 12, 2013, 12:50:05 AM »
Hi All,
Please Help.
I am trying to write a routine which will insert the block (with attributes).
The problem is I have many different drawings (Symbols) to be insert as block, each has different attribute properties and I am eager to insert it with Entmake but writing ATTDEF for each symbol will consume the lot of time. I have a routine with ActiveX method but I think Entmake is the fastest one as there are more than 100,000 locations in which the block will insert.
Is there a way I can once select a Drawing Symbol whichever I want and the routine will create all the necessary ATTDEF properties based on the selected one?
Any help will be highly appreciated.
Thanks and Regards
Aaryan.
