Author Topic: Looking for a list of all annotative entities  (Read 2006 times)
roy_043
  • BricsCAD 18
« on: November 08, 2013, 06:18:58 AM »
I am looking for a list of all annotative entities.
This is what I have so far:
ARC_DIMENSION
ATTDEF
ATTRIB
DIMENSION
HATCH
INSERT
LEADER
MTEXT
MULTILEADER
TEXT
TOLERANCE
Are these annotative?:
ARCALIGNEDTEXT
RTEXT
LibertyOne
Re: Looking for a list of all annotative entities
« Reply #1 on: November 11, 2013, 04:13:08 AM »
3 Point Angular Dimension
Aligned Dimension
Angular Dimension
Arc Length Dimension
Attribute
Attribute Definition
Diametric Dimension
Jogged Dimension
Leader
MText
Multileader
Ordinate Dimension
Radial Dimension
Rotated Dimension
Text
Tolerance
roy_043
  • BricsCAD 18
« Reply #2 on: November 11, 2013, 06:58:41 AM »
Thank you. As far as I can tell your list matches my first list (ARC_DIMENSION - TOLERANCE). So I guess ARCALIGNEDTEXT and RTEXT are not annotative.
